Welcome, Guest.
| AutoCAD Electrical - General Ask your AutoCAD Electrical questions here! |
Thread Tools | Display Modes |
#1 |
Does anyone else do Single Line Diagrams for documenting of power distribution systems?
i.e. where a single line intersected with three short diagonal dashes (usually representing a cable) drawn through single pole components is used to create a simplified drawing version of a three phase installation, most commonly used when drawing commercial/industrial switchboards. If so, have you found any provision for this type of drawing in AutoCAD Electrical? I may be wrong, or I may just have not looked hard enough yet, but I can't seem to find any symbols or settings that can be used for this purpose, nor does it appear that any of the logic of the database operations within AutoCAD Electrical are set up to cater for this type of drawing. |
#2 | |
Oh well, I might post a small library of symbols once I get them done then. They may not be a whole lot of help to most though, as they will be to Australian Standards. |
#3 |
Well, I don't know why you couldn't just use single fuses & circuit breakers and manually draw a single line schematic. You could even add wire layers for the correct sizing. I don't think that there is a "1 Line drawing" format setup in AcadE though just "Point to Point" wiring. You will probably have to create new blocks for transformers and other "1 Line" components. I'm not sure how AcadE would resolve the differences with 1 line dwgs.
#4 | |
It would be nice to be able to draw a true single line diagram and not have to fudge the part numbers one way or another - that was the point of my original post. It would also be nice to have the database cope with this situation natively and add the correct annotation to the drawing where required when drawing in "single line" mode. I guess the essence of my question was "Is the 'single line drawing' something that is unique to Australian draughting, or is it used woirld wide?"
__________________
The letter I have written today is longer than usual because I lacked the time to make it shorter - Blaise Pascal |
#5 |
We aren't using ACADE (yet) but single line diagrams are an essential part of utility design work. At least the ones I have experience with. (USA)
Are you working in the electrical distrubtion industry? If so I would like to discuss your current uses of ACE sometime. We are in the process of researching ECAD applications. Thanks. |
#6 |
Not as such, no. we own the high voltage assets on our site, though, so we have to document the 7 substations across our 50 acre site (ranging from 750kVA to 1.5MVA) and all of the downstream equipment, both industrial and domestic.
At the moment I mainly use ACADE for its project management capabilities, which is actually really useful to me. I'm still waiting for the opportunity to see how it goes on a small to medium project where absolutely everything that's being installed is brand new. I find that it's a bit limiting to be trying to integrate an existing set of drawings into a new project where you are expanding an existing installation. Not impossible, but there's only so much time that you can allocate to redrawing existing drawings before it becomes unjustifiable. I think it would be much more successful on a brand new project where every component used is fully compliant with the standards and uses a proper AutCAD Electrical block symbol.
__________________
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Looking for a routine to draw building outlines | boesiii | AutoLISP | 10 | 2008-08-14 04:53 AM |
| Hatches, fills and lines | trombe | Revit Architecture - General | 6 | 2007-02-01 05:22 PM |
| Breaking info on AutoCAD 2006 | Mike.Perry | AutoCAD General | 6 | 2005-07-06 10:25 PM |
| Autodesk Feedback Request: Multi-line Attributes | eric.stover | AutoCAD "Original" Wish List (Archived) | 4 | 2005-05-20 06:53 PM |
| Single view reference line | Fred Blome | Revit Architecture - General | 2 | 2005-03-18 01:16 AM |
