Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2005-08-04, 09:44 PM   #1
cmason.82472
cmason.82472 is starting their journey
Smile OLE object
I am trying to insert an Excel spreadsheet into Acad '04 Electrical.
The max size it will insert is. 16x50, and my spreadsheet is around 20x140.
I was able to connect to it useing dbconnect, but I don't know how to display it or plot it.
Any help, I would be grateful.
thanks
__________________
Chris
cmason.82472 is offline   Reply With Quote
Old 2005-08-04, 10:09 PM   #2
Mike.Perry
Administrator
Mike.Perry's Avatar
Mike.Perry has disabled reputation
Default RE: OLE object
Hi
For starters take a look at the information contained within the following couple of threads found in the AutoCAD FAQ forum -
OLE (eg Excel) Objects within drawing file not Plotting correctly
Working with OLE (eg Excel) Objects within a drawing file
Have a good one, Mike
__________________
..........MeWhee
Mike.Perry is offline   Reply With Quote
Old 2005-08-05, 02:55 PM   #3
cmason.82472
Default
I don't think OLE objects are going to work for what I need to do, unless I do some piecing together. I was able however, to set up my spreadsheet as an ODBC and bring it in using db connect. I was wondering if it is possible to display that in my drawing. And plot a large spreadsheet all at once.
__________________
Chris
Old 2005-08-05, 06:44 PM   #4
RobertB
Administrator
RobertB's Avatar
RobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the stars
Default
What version of Excel? You need to be running Excel XP or 2003, along with Win2k or WinXP, in order to get large OLE areas from Excel.
RobertB is offline   Reply With Quote
Old 2005-08-05, 07:43 PM   #5
cmason.82472
Default
Excel 2000 with windows 2000
__________________
Chris
Old 2005-08-05, 11:17 PM   #6
RobertB
Administrator
RobertB's Avatar
You are out of luck. Tell your boss you need an upgrade.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Problems with selecting objects eg. Only able to select 1 object at a time. Mike.Perry AutoCAD FAQ (Read only) 0 2005-07-09 01:27 AM
Select last object selection. bskripac AutoCAD General 4 2005-02-10 03:22 PM
reference an object's definition to another object property definition? JBACHMAN ACA General 0 2005-02-09 10:08 PM
Quality Drawings; Object Styles, View Temp's & Vis Overr jacob chavez Revit Architecture - General 3 2004-12-10 07:23 AM
Dockable Interface, Object Browser, Object handle ideas... Richard McCarthy Revit Architecture "Original" Wish List (Archived) 6 2003-10-08 07:49 PM
