Hi all,
we posted a new build for Download.
Here are the improvements in this build since the last RTW from September 14th:
- Fixed a bug that caused a crash after changing a type parameter followed by an instance parameter.
- Adds the Revit icon to the Windows Add/Remove Programs tool.
- Corrects a problem that prevented some installs when using Windows 2000 OS.
- fix that allows for less memory usage
- Performance improvements or save to central
- fixed a problem with lining up DWG files in Revit if they have far away origin
- fixed issues during rotation of roofs
- fixed crashes provoked by the offset command
- fixed crash provoked by editing Color Fill Scheme settings
- Fixed a problem when that made ACAD'a Batch Plot Utility not work when Revit was uninstalled
- Fixed the issue that select all mullions on curtain wall provoked crashes
- Fixed a response lag when creating Ref. plane
- Fixed a problem with Plan region improperly exposing Structure elements in link file
- Fixed an error in German, Italian, and French localized versions that prevented viewing parts of the Help file.
- Improves install performance for certain aspects of German, Italian, and French localized versions.
- Fixes a problem that caused the incorrect default template to be loaded in some localized Revit versions.
thanks
TD
