Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: block count only in current space/layout
    2005-05
    102
    Angry block count only in current space/layout
    I came across this handy lisp routines that count blocks. The problem i have that it also counts the blocks in the paperspace. I would like for someone to modify this lisp routine to only count in current drawing. for example, if i am in model space, count only blocks in model space. and If i am in paper layout, count only blocks in a paper layout.
    You can either modify the lisp routines or create your own. Thank You
    2001-12
    St. Louis
    5,421
    Talking Re: block count only in current space/layout
    Quote Originally Posted by VBOYAJI
    Hi there... just wanted to let you know that I've removed the attachment, as AUGI doesn't allow the posting of copyrighted material.
    I'm sure someone will still be able to help you with the information contained in this thread.
    Thank you.
    here is the header info
    CADALYST 01/05 Tip2015: BLCX.lsp Block counter (c) Alexander Smirnov
    This program counts blocks, gives out the reporting, +
    ;;; and also can export the data to MS Excel. +
    ;;; Type BLCX in command line to run. +
    ;;; Supported O/S: Windows 2000/XP +
    ;;; Suppported MS Excel Versions: MS Office 97/2003 +
    ;;; Supported AutoCAD Versions: AutoCAD 2000/2005 +
    ;;; Writen by Fantom (Alexander Smirnov) asmirnov@inbox.lv +
    ;;; Version 1.0 Dec 09, 2004
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2005-05
    102
    Default Re: block count only in current space/layout
    Fine, I get it now. No more posting codes that written by someone else. I am clear now. Even though i made it clear it wasn't my code. One last thing, i got this code from AUGI member, from AUGI website. Any how, can someone tell me how to resolve the issue i was facing in my original thread.
    Thank You
    2015-12
    Central Oregon
    591
    Looking at the code as posted to the Cadalyst website (under Hot Tip Harry's Feb05 code) it was originally written for the user to select the blocks. Based on what your question was, I'd venture a guess that someone changed the (ssget '((0 . "INSERT"))) to (ssget "x" '((0 . "INSERT"))) to select ALL blocks.....if that's the case, just change the same line to: (ssget "x" (list '(0 . "INSERT") (cons 410 (getvar "ctab")))) this will select All blocks ONLY in the current Tab.
    HTH,
    Jeff
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Give this my routine that was written some time ago for my mate
    but I think that it is what you need
    Change all by suit
    Thank you
    f.
    2005-05
    102
    Unhappy Re: block count only in current space/layout
    I tried in doing that, but it seems that i am getting an error.
    this what i am doing,
    **********current code**********
      (if(setq blSet(ssget '((0 . "INSERT"))))
    **********This is the change i made according to your suggestion:**********
    Quote Originally Posted by miff
    HTH,
    Jeff
    [ Moderator Action = ON ]Copyright material removed[ Moderator Action = OFF ]
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,203
    I think if you place the (if at the beginning of the line of code you modified, it should work.
    (if(ssget "x" (list '(0 . "INSERT") (cons 410 (getvar "ctab"))))
    2005-05
    102
    Cool Re: block count only in current space/layout
    It tried and did not work, I was wondering if you can download the lisp routine and try it.
    Here is the website:
    http://new.cadalyst.com/code/browsey...?fullyear=2005
    By the way, I appreciate your help very much.
    Thank You
    vboyaji
    Quote Originally Posted by Opie
    2015-12
    Central Oregon
    591
    Thank You
    vboyaji
    I downloaded the original, changed the one line to this:
    (if(setq blSet(ssget "X" (LIST '(0 . "INSERT")(CONS 410 (GETVAR "CTAB")))))
    and it worked fine......when you say "it did not work", did it give an error message or just not do anything?
    Jeff
    2005-05
    102
    It worked fine.
    Thank you
  1. Layer Frozen/Off Status in Model Space/Layout Space
    Last Post: 2013-01-17, 04:29 AM
  2. Replies: 0
    Last Post: 2011-10-21, 06:44 PM
  3. Layout Count
    By sam.121498 in forum AutoCAD Fields
    Last Post: 2010-01-21, 07:53 AM
  4. model space or layout space
    By jim.dobinson in forum CAD Standards
    Last Post: 2005-11-24, 01:16 AM
  5. model space to layout space going from LT-05 to AC-06
    By crater59 in forum AutoCAD LT - General
    Last Post: 2005-09-22, 12:05 AM
