Thread: ADT 2007 .NET API HardwiredStyles Samples
    2006-04
    2
    Default ADT 2007 .NET API HardwiredStyles Samples
    The AecHardwiredStylesMgd ADT 2007 .NET API samples (C# and VB) have some problems. The defects in the sample prevent the drawing from being saved after it is run. The only way to exit is to quit without saving.
    We have updated the samples and are attached to this posting. Please use the attached samples in place of the existing samples.
    Sincerely,
    Kevin Vandecar
    Software Engineer
    Autodesk
    Default Re: ADT 2007 .NET API HardwiredStyles Samples
    Thanks for the update!
    Administrator richard.binning's Avatar
    2015-12
    In the foothills of the appalachians
    2,261
    Thanks Kevin!
    Having the development teams in our forums is great!
    RLB
  1. elevation tag samples
    By frame in forum Revit Architecture - General
    Last Post: 2009-11-08, 11:07 PM
  2. Samples?
    By Beth Powell in forum Revit - Rendering
    Last Post: 2006-11-30, 07:15 PM
  3. Samples?
    By acad in forum Revit Architecture - General
  4. 6.0 Samples Library.
    By David Conant in forum Revit Architecture - General
    Last Post: 2003-12-20, 09:05 AM
