Thursday, July 29, 2010
Go Back   AUGI Forums > AUGI Technical (English) > General Design > AutoCAD > AutoCAD Support > AutoCAD General
 Welcome, Guest.
Login
AutoCAD General Ask your AutoCAD 2010 or below "general" questions here!
Reply
Thread Tools Display Modes
Old 2006-05-02, 07:45 AM   #1
nathanh
nathanh is starting their journey
Default UCSFollow variable not saved within drawing
Whenever I set the UCSFOLLOW variable to 1, it always defaults back to 0 if I close the file and re-open it. This is very frustrating as I have to change it every time I open the drawing.
I never had a problem with this on older versions of AutoCAD (2006 and earlier).
Is there something I need to do to make sure this does not re-set?
Thanks.
nathanh is offline   Reply With Quote
Old 2006-05-02, 08:15 AM   #2
Mike.Perry
Administrator
Mike.Perry's Avatar
Mike.Perry has disabled reputation
Default RE: UCSFollow variable not saved within drawing
Hi
As far as I know the behaviour of UCSFollow has not been altered in AutoCAD 2007.
Is it being automatically set within a file like...
Acad.lsp
AcadDoc.lsp
Custom.mnl
etc
Just checking here...
You do realise UCSFollow is per Tab ( Model and Layout(s) ) and per Floating Viewport ?
Have a good one, Mike
__________________
..........MeWhee
Mike.Perry is offline   Reply With Quote
Old 2006-07-25, 03:03 PM   #3
philpiper
Location: On the other side of the pond, where they speak real English!
philpiper is glowing brightlyphilpiper is glowing brightlyphilpiper is glowing brightlyphilpiper is glowing brightlyphilpiper is glowing brightlyphilpiper is glowing brightlyphilpiper is glowing brightlyphilpiper is glowing brightlyphilpiper is glowing brightly
I've found the same problem as you, so have contacted Autodesk to see if this is a bug with 2007. Apparently it is and they are aware of it. They have sent a Lisp file as a short term workaround solution for now. Basically, all it does is force UCSFOLLOW to 1 each time a drawing is opened. Works great - just copy it into the SUPPORT directory of AutoCAD and you're away.
File Type: lsp acaddoc.lsp (50 Bytes, 45 views)
philpiper is offline   Reply With Quote
Old 2007-03-29, 12:21 AM   #4
dick.dudley
dick.dudley is starting their journey
7 months later and I still having the same issue...
Is this lisp routine still the best work around? Will this be fixed in v2008?
dick.dudley is offline   Reply With Quote
Old 2007-09-27, 10:32 PM   #5
cblackford
cblackford's Avatar
cblackford has a bright futurecblackford has a bright futurecblackford has a bright futurecblackford has a bright futurecblackford has a bright futurecblackford has a bright future
Default Re: UCSFollow variable not saved within drawing
Over a year later, we are now having this problem on about half of the machines in the office. It started with the upgrade to 2008. Does anyone have a better solution than switching the setting via startup lisp. That kind of goes against the whole reason the setting is file specific in the first place, doesn't it?
cblackford is offline   Reply With Quote
Old 2007-09-28, 12:10 AM   #6
Firmso
Firmso's Avatar
Firmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of light
Thanks.
Just curious. Have you played around with VISRETAIN?
Not sure whether it has anything to do with the ucsfollow, but whenever I have issues with layers and viewports this is one of the first things I check and most of the time it does.
__________________
"For his anger lasts only a brief moment, and his good favor restores one's life. One may experience sorrow during the night, but joy arrives in the morning." Psalms 30:5
Firmso is offline   Reply With Quote
Old 2007-09-28, 12:29 PM   #7
ccowgill
ccowgill's Avatar
ccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the stars
according to help, the setting is ignored in paperspace, and is kept separate from modelspace, or from inside each viewport. we have ours set at 0 as we dont have a necessity to change it otherwise, I have no problem working at an angle to the drawing space.
__________________
Christopher T. Cowgill, P.E.
WIGHTMAN JONES, INC.
CONSULTING ENGINEERS & LAND SURVEYORS
AutoCAD 2011/2010 v3 64
XP Pro 64bit SP2 (Home)
Windows 7 Ultimate 64bit (Work)
ccowgill is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
System variable to stop Layers being copied from one drawing file to another GuinnessCAD AutoCAD General 4 2006-03-17 12:47 PM
When drawing were opened and saved acadwishlist ACAD-002 (Archived) 0 2006-03-07 06:32 PM
Run a script that sets Variables from a button or drawing startup. SRBalliet AutoCAD Customization 9 2006-02-21 11:45 AM
XClip objects viewable when being moved BCrouse AutoCAD General 65 2005-07-27 11:10 PM
Plot Style Tables (CTB or STB) gone south Mike.Perry AutoCAD FAQ (Read only) 1 2005-04-02 04:56 PM
