Tuesday, February 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit Architecture Support > Revit Architecture - Tips & Tricks
 Welcome, Guest.
Login
Revit Architecture - Tips & Tricks Got a hot tip? Share it here!
Reply
Thread Tools Display Modes
Old 2006-05-09, 06:32 AM   #1
Scott Hopkins
Scott Hopkins's Avatar
Scott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moon
Lightbulb How to Order Revit Parameters
Let me start by saying that this tip is pure gold!
It is such a great work around that I really hate to give it away. Once I do, the Factory will probably never develop a proper fix for parameter ordering. After much trial and error I discovered this trick a few months back. I have been feeling kind of selfish keeping it all to myself.
Well my fellow Reviteers, the cat is now out of the bag...
__________________
Revit 2010 - Autodesk commences "Operation Destroy Revit"
Scott Hopkins is offline   Reply With Quote
Old 2006-05-09, 06:51 AM   #2
iru69
iru69 has disabled reputation
Default RE: How to Order Revit Parameters
Gold, Jerry, gold!
However, the Factory still needs to address this issue - while that's a great workaround for inserting new parameters, it doesn't help re-order parameters that have already been created. Usually when I'm developing a complicated family with a lot of parameters, I don't know what order I want them in until I've finished the family.
iru69 is offline   Reply With Quote
Old 2006-05-09, 06:48 PM   #3
jcdecastro
jcdecastro's Avatar
jcdecastro has a bright futurejcdecastro has a bright futurejcdecastro has a bright futurejcdecastro has a bright futurejcdecastro has a bright futurejcdecastro has a bright future
This is nice!!!!!!!!
I am going to remake my specialty equipment 'templates' like this.
Currently the Width, Depth and Height are alphabetical order. This way will cut down on input errors.
jcdecastro is offline   Reply With Quote
Old 2006-05-10, 02:44 PM   #4
narlee
narlee is glowing brightlynarlee is glowing brightlynarlee is glowing brightlynarlee is glowing brightlynarlee is glowing brightlynarlee is glowing brightlynarlee is glowing brightlynarlee is glowing brightlynarlee is glowing brightlynarlee is glowing brightlynarlee is glowing brightly
Nice work, Scott. How in blazes did you ever figure that out?
I found that to "re-order" existing parameters (as oppossed to "adding" parameters), I had to go back into the sketch and re-label the dimension, then go back to the dialogue box and finalize the parameter deletions and name modifications.
Also, I found that when I loaded the "revised" family into a project that had the "old" family, it did NOT load the "revised" parameters order. But, if I loaded the "revised" family into a project that did not have the "old" family, it DID load the "revised" parameters order.
Geof.
narlee is offline   Reply With Quote
Old 2006-05-10, 08:46 PM   #5
ingsusca
ingsusca's Avatar
ingsusca is starting their journey
Really great!
__________________
Antonio SUSCA
Civil Engineer
Italy
ingsusca is offline   Reply With Quote
Old 2006-05-10, 10:35 PM   #6
bowlingbrad
bowlingbrad's Avatar
bowlingbrad is reaching for the moonbowlingbrad is reaching for the moonbowlingbrad is reaching for the moonbowlingbrad is reaching for the moonbowlingbrad is reaching for the moonbowlingbrad is reaching for the moonbowlingbrad is reaching for the moonbowlingbrad is reaching for the moonbowlingbrad is reaching for the moonbowlingbrad is reaching for the moonbowlingbrad is reaching for the moon
You know, Scott, I hear it's really nice outside year-round in California.... GET OUT!!!
And by the way... thanks for the tip.
__________________
Brad Novak
Director of Information Technology
goettsch partners
Chicago, IL
bowlingbrad is offline   Reply With Quote
Old 2006-05-11, 06:24 AM   #7
Scott Hopkins
Red face RE: How to Order Revit Parameters
Is it that obvious that I am a total Revit junkie? What can I say... when the surf is flat I end up spending too much time working. I make a lot of very complex families so I guess I get a little over excited about things that make my life easier.
__________________
Old 2006-05-12, 02:33 AM   #8
bill.adams
AUGI Director
bill.adams's Avatar
bill.adams has disabled reputation
Thanks Scott - what a great tip...
__________________
Cheers Bill (aka blads the Forum Poet)
Secretary, AUGI Board of Directors
Mac Pro | Macbook Pro
SA Revit Users Group
bill.adams is offline   Reply With Quote
Old 2006-05-13, 05:59 AM   #9
iru69
It seems as though I ran into another limitation of this technique: shared parameters.
Old 2006-11-09, 10:42 AM   #10
rudolfesterhuyse
rudolfesterhuyse is starting their journey
Excellent! Thanks!
rudolfesterhuyse is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Tips for Installing Autodesk Revit Building 8 using the Web Installer tatlin Revit Architecture - General 2 2005-06-15 06:06 AM
Common Revit Myths... I want to hear the one's you've been hearing! Jeffrey McGrew Revit Architecture - General 9 2004-08-28 04:37 AM
What are Parameters? M. Stephenson Revit Architecture - General 5 2003-08-15 08:29 PM
