Welcome, Guest.
| AutoLISP AutoLISP or Visual LISP, learn both here! |
Thread Tools | Display Modes |
#1 |
Is there an area where I can get a list of all LSP commands and their function?
#2 |
Administrator
All the LISP functions are documented in the Developer's Guide, which can be found via the Help menu (or the VLIDE's Help menu).
#3 |
Wish List Manager
Moved the correct forum
#4 |
Ummm, are you sure this is the right forum?
-Tripp (oops, never mind. it did move after all...) Last edited by tmullins : 2004-06-02 at 08:15 PM. |
#5 |
if I in VLISP write this line:
(vla-add and then pressing CTRL+SHIFT+SPACEBAR to call the "Apropos results" scrolling to a symbol and double-clicking on it VLISP displays the "Symbol Service" dialog box for the selected function If I then press the Help button [ ? ] in the Symbol "Service dialog box". I only get "page can not be found". What can be wrong ? : ) Happy Computing kennet |
#6 |
Works for me. !
As a process of elimination : Does it do that for ALL symbols ? How about when you open the Help file first, via the Menu bar : Help->VisualLisp Help Topics ? How about when you highlight the Vla-add in the IDE and press Ctrl-F1 ?? oh, yes, someone is sure to ask : which Version of ACad ? regards.Kerry |
#7 |
Thank you Kerry, but no luck
1. All symbols blanc 2. Only one item, vla-addLightweightPolyline 3. Not found 4. 2002 : ) Happy Computing ! kennet |
#8 |
Administrator
The Help files have always had their ups and downs, especially 2002's VLIDE files. All the vla- functions are "documented" in the ActiveX Reference, just drop the "vla-" and look for the remainder of the string.
#9 |
Moderator
#10 |
kennet :
Do you have these files on your computer ?? ...\Acad2002\Help\acadauto.chm ...\Acad2002\Help\acad_aag.chm |
| Thread Tools | |
| Display Modes | |
