Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-03, 07:35 PM   #1
denton
denton's Avatar
denton is starting their journey
Default Leader Lisp Routine that puts in the Elevation
Does anyone have a lisp routine that will put in a leader line and print out the elevation (Z coordinate) as EL 100.00?
denton is offline   Reply With Quote
Old 2004-06-03, 10:36 PM   #2
Coolmo
Coolmo's Avatar
Coolmo is glowing brightlyCoolmo is glowing brightlyCoolmo is glowing brightlyCoolmo is glowing brightlyCoolmo is glowing brightlyCoolmo is glowing brightlyCoolmo is glowing brightlyCoolmo is glowing brightlyCoolmo is glowing brightlyCoolmo is glowing brightlyCoolmo is glowing brightly
Default RE: Leader Lisp Routine that puts in the Elevation
Z coordinate of what? The node or point that the leader is pointing to or would the user type an elevation?
Coolmo is offline   Reply With Quote
Old 2004-06-04, 01:58 PM   #3
peter
Vice President / Director
peter's Avatar
peter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the stars
Maybe?
Peter Jamtgaard
(defun C:LEAD100 ()
 (vl-cmdf "leader" pause pause "" "100.00" "")
peter is offline   Reply With Quote
Old 2004-06-04, 06:06 PM   #4
RobertB
Administrator
RobertB's Avatar
RobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the stars
Default
Peter, I think Denton wants the Z-coord of the object the leader points to.
Denton, what version of AutoCAD?
RobertB is offline   Reply With Quote
Old 2004-06-07, 03:26 PM   #5
denton
denton's Avatar
Thanks but I got what I needed from a different forum thank you anyway.
Old 2008-05-13, 03:32 PM   #6
steve.perkio
steve.perkio's Avatar
steve.perkio appears to be going the right way
Default Re: Leader Lisp Routine that puts in the Elevation
I asked for Denton' help with this issue, and basically got a No Thank you, I'm not going to help you reply. See the attached pdf.
Thanks Denton.
steve.perkio is offline   Reply With Quote
Old 2008-05-13, 03:38 PM   #7
denton
denton's Avatar
Thanks Denton.
I'm sorry if I misunderstood you, I was not being rude, what help did you want on this? This post was so long ago I'm a little foggy on it. Do you want the routine?
Old 2008-05-13, 05:26 PM   #8
tedg
tedg's Avatar
tedg is shooting for the starstedg is shooting for the starstedg is shooting for the starstedg is shooting for the starstedg is shooting for the starstedg is shooting for the starstedg is shooting for the starstedg is shooting for the starstedg is shooting for the starstedg is shooting for the starstedg is shooting for the stars
I think "steve.perkio" was asking if you had received an answer or resolution to your question, and if so could you point him in the right direction and/or share what you got.
That's my take on it anyway...
__________________
Ted
Those who master others have Force.
Those who master themselves have Strength.
tedg is offline   Reply With Quote
Old 2008-05-13, 05:39 PM   #9
denton
denton's Avatar
Smile Re: Leader Lisp Routine that puts in the Elevation
Could be, but he seemed upset which was not my intention. Here's the routine for what it's worth. It some functions I use locally for looking up and restoring variables that should be commented out (initerr) and (reset):
;;; LISP: Elead.lsp
;;; Version 1.0   	D.D. Denton 6/3/04
;;;			Western Area Power Administration
;;;			email: denton@wapa.gov  720-962-7360
;;; Purpose:		Leader line that automatically labels elevations.
(defun elead (/ point ldrent oldecho lastent txtent coord2)
  (initerr)
  (vl-load-com)
  (command "ucs" "w")
	(defun laycheck ( / laychk)
	(setq curlayer (getvar "clayer"))
	(setq laychk (cdr (assoc 2 (tblsearch "layer" "dimen"))))
	(if (= laychk nil) (command "layer" "m" "dimen" "c" 6 "" ""))
  	(command "layer" "s" "dimen" "")
  (setvar "cmdecho" 0)
  (laycheck)
  (check_dim "dim-arrow-leader")
  (command "ortho" "off")
  (command "osnap" "end")
  (setvar "luprec" 2)
  (setvar "lunits" 2)
  (while (setq point (getpoint "\nSelect point to label: "))
    (setq oldecho (getvar "cmdecho"))
    (setq lastent (entlast))
    (command "_.leader" point)
    (princ "\nNext leader point: ")
    (command pause)
    (command pause (strcat "EL " (rtos (caddr point)))
    (setq txtent (vlax-ename->vla-object (entlast)))
    (setq ldrent (vlax-ename->vla-object (entnext lastent)))
    (setq coord2 (vlax-safearray->list
     (vlax-variant-value
       (vla-get-coordinate ldrent 1))))
    (if (< (/ pi 2) (angle coord2 (getvar "lastpoint")) (* pi 1.5))
      (vla-put-attachmentpoint txtent acAttachmentPointMiddleRight)
      (vla-put-attachmentpoint txtent acAttachmentPointMiddleLeft)
    (vla-put-insertionpoint txtent (vlax-3d-point (getvar "lastpoint")))
    (vla-put-VerticalTextPosition ldrent acVertCentered)
    (setvar "cmdecho" oldecho)
  (princ)
  (command "ucs" "v")
    (reset)
(defun c:elead () (elead))
Moderator Note:
Please use [ CODE ] tags...
Last edited by Opie : 2008-05-13 at 07:08 PM. Reason: [CODE] tags added, see Moderator Note
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
