Thursday, July 29, 2010
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit Architecture Support > Revit Architecture - General
 Welcome, Guest.
Login
Revit Architecture - General Main discussion area for the latest release of Revit Architecture.
Reply
Thread Tools Display Modes
Old 2006-06-28, 10:50 PM   #1
dgraue
dgraue's Avatar
dgraue is going the right waydgraue is going the right waydgraue is going the right way
Default Is making a Key Plan really that hard?
How are you putting Key Plans on your sheets? I have a large multistory building and need to show enlarged plans on multiple sheets for each level. I need to drop a Key Plan on each enlarged plan sheet to show the location in the building the plan occurs by shadding that area of the Key Plan. The only way I can figure to do this is to duplicate a region filled drafting view a dozen times to drop onto each sheet or to print a pdf of the Key Plan and make it into a Jpg in Photoshop and import the Jpg image onto the sheet.
A Key Plan is as basic a need to drawing sheets as is a north arrow. That said, I guess I could create a generic family for each Key Plan and bring that in. But, the drawback here is that you can not bring in the outline of your project into the generic family...so you will need to draw its profile from scratch.
Any other ideas?
Thanks.
DG
dgraue is offline   Reply With Quote
Old 2006-06-28, 11:00 PM   #2
david.kingham
NavisWorks Moderator
david.kingham's Avatar
david.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moon
Default RE: Is making a Key Plan really that hard?
I first export to dwg, delete what i dont want to see in the dwg, then import that into a legend, put a filled region where you want to shade, have to create a different legend for each shaded area but at least not for each sheet
david.kingham is offline   Reply With Quote
Old 2006-06-28, 11:30 PM   #3
Firmso
Firmso's Avatar
Firmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of lightFirmso is a beam of light
Will inserting the plans under Legend work? Just like cretaing any other legend.
__________________
"For his anger lasts only a brief moment, and his good favor restores one's life. One may experience sorrow during the night, but joy arrives in the morning." Psalms 30:5
Firmso is offline   Reply With Quote
Old 2006-06-29, 12:39 AM   #4
dgraue
dgraue's Avatar
Legends...good idea. That will work nicely.
Thanks David.
Old 2006-06-29, 02:42 AM   #5
eldad
eldad's Avatar
eldad has a bright futureeldad has a bright futureeldad has a bright futureeldad has a bright futureeldad has a bright futureeldad has a bright futureeldad has a bright futureeldad has a bright future
A simple way is to create a generic annotation family, more or less the shape of your building if you like, than just create field regions with yes/no parameter you can turn on and off according to your location
that way you create one family you can reuse. I tried to upload the family but our much loved (not) mime sweeper is stopping me
email me if you want it
__________________
Eldad Asoulin
Integrator AEC
KarelCAD
www.karelcad.com.au
eldad is offline   Reply With Quote
Old 2006-06-29, 04:41 AM   #6
dbaldacchino
Count (Formula)
dbaldacchino's Avatar
dbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining star
I'm doing it similar to Eldad...Generic Annotation nested in a titleblock family (we show the keyplan on each sheet on the left, outside the drawing area). I did a Print Screen of my floor plan, saved it to a jpg, inserted it in the border family and scaled it down to about 3" or so. Then I traced over and did filled regions and letters to designate the areas, and used Yes/No parameters to control visibility. I saved this family and inserted it in the border family. Then I tied the visibility parameters to others I created in the border. By default I left all filled regions turned off so when you create a new sheet, you get a clean keyplan showing all areas, but none is hatched. Then you select the border properties and turn on the area you want. Works like a charm.
__________________
dbaldacchino is offline   Reply With Quote
Old 2006-06-29, 05:39 AM   #7
patricks
Certified AUGI Addict
patricks's Avatar
patricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moon
so you create different title blocks for every project? We don't do that, we have one titleblock for each sheet size and just put in the project info on each project.
On my last big project I also did a keyplan as a generic annotation with yes/no parameters on the different filled areas. Then I placed one, and pasted same place to get them in the exact same spot on every plan sheet, and then adjusted the yes/no parameters for each instance. I think it worked pretty well. As far as the building outline, it was fairly simple and I was able to approximate it just by drawing lines freehand in the generic annotation family editor.
__________________
Intern Architect
AERC, PLLC
Hernando, Mississippi
patricks is offline   Reply With Quote
Old 2006-06-29, 05:42 AM   #8
eldad
eldad's Avatar
I don't have it as part of the title block, but you could duplicate the title block and insert when needed... many ways to skin a cat
__________________
Eldad Asoulin
Integrator AEC
KarelCAD
www.karelcad.com.au
Old 2006-06-29, 03:09 PM   #9
dbaldacchino
Count (Formula)
No, we have our standard title block. Then we have to "customize it" with client's logo, (school districts), consultant logos etc just once, at the beginning of the project. All I do is nest the symbol (generic annotation) inside the border and connect it to the A, B, C, D, E (instance parameters) etc. that designate the plan areas (each of these areas fits on an AP sheet @ 1/8" scale). It doesn't matter if this is done at the end of DD as it'll show up on all created sheets. The user just has to turn on the right areas for each sheet.
As I said, by default when you create a new sheet and select the titleblock, the keyplan comes in with all filled regions turned off. All the user does then is select the border, go to properties and check the area that the sheet pertains to and the hatch region turns on.
__________________
Old 2006-06-29, 03:18 PM   #10
ford347
ford347's Avatar
ford347 is reaching for the moonford347 is reaching for the moonford347 is reaching for the moonford347 is reaching for the moonford347 is reaching for the moonford347 is reaching for the moonford347 is reaching for the moonford347 is reaching for the moonford347 is reaching for the moonford347 is reaching for the moonford347 is reaching for the moon
Would any of you mind posting an image of what you are explaining and how the key plan actually looks. I am trying to adapt new methods for our firm, and since our projects don't exceed a certain size most of the time, I am always interested in how larger firms do things. Just curious.
ford347 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Model geometry vs. symbolic lines in plan patricks Revit Architecture - Families 3 2005-12-13 09:24 PM
Referencing Detail Plan Callouts. beegee Revit - Known Issues & Work-Arounds (Read only) 0 2005-06-27 01:36 AM
In-place family visibility in Plan view patricks Revit Architecture - Families 9 2005-06-09 06:21 AM
Underlays displaying as RCP instead of Floor Plan darrenl Revit Architecture - General 8 2004-12-04 12:12 AM
"lines" go across doors and wndws in plan view markjnstne ACA General 3 2004-11-23 09:23 PM
