Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-05, 08:55 AM   #1
Robert Platt
Robert Platt is starting their journey
Default Updating Attributes
I have a small programme that allows a user to calculate an area from a polyline and to update an attribute with the area. Previously (with earlier versions of AutoCAD) it worked fine and immediately updated the attribute on screen. Now, when I run it in AutoCAD 2004, it does not update the attribute until I do a regen. I'd like to know if the functionality of the "entupd" command has changed in AutoCAD 2004, and if there is way to work around this problem.
Robert Platt is offline   Reply With Quote
Old 2004-06-05, 04:52 PM   #2
stig.madsen
stig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightly
Default RE: Updating Attributes
Originally Posted by plattrj
I'd like to know if the functionality of the "entupd" command has changed in AutoCAD 2004, ...
I wouldn't know if it changed, but be sure to update the parent insert with ENTUPD. That should save you from a global regeneration.
stig.madsen is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
updating level names and unloading links sfaust Revit - Worksharing/Worksets 1 2004-04-05 08:03 PM
Wish-Type Catalog updating nrenfro Revit Architecture "Original" Wish List (Archived) 0 2004-02-12 10:00 PM
Folder updating batch file PeterJ Revit Architecture - General 4 2003-12-20 07:13 AM
updating Revit 5.1 wjspence Revit Architecture - General 1 2003-08-06 05:21 PM
Changing attributes within a family after the fact... John K. Revit Architecture - Families 0 2003-05-16 05:09 AM
