Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-07, 11:02 PM   #1
rabitsarchitects
rabitsarchitects is starting their journey
Default Need Help Deleting "Named Layer Filters"
Does anybody have a LISP routine or anything else that I could use to delete "Named Layer Filters ??
I'm finding drawings with Hundreds maybe Thousands of Named Layer Filters. They are all useless. They are just junk brought over from previous drawings. I deleted the Layer filters from one drawing and it dropped the file size by over 500k. If I can find something to run on all our drawings this would free up an enormous amount of space...\
Thanks for any help you can give...
Rob G.
rabitsarchitects is offline   Reply With Quote
Old 2004-06-08, 12:13 AM   #2
RobertB
Administrator
RobertB's Avatar
RobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the stars
Default RE: Need Help Deleting "Named Layer Filters"
I have posted this code in several places; I guess I should here also!
Written by: 	R. Robert Bell
Purpose:	Allows the user to enter a wildcard string to keep any matching filters.
Sample string:	"`#*,MW*" will keep all filters beginning with a "#" or "MW"
Copyright © 2004 by R. Robert Bell
(defun rrbI:LayerFiltersDelete  (strKeepWC / objXDict)
 ;; This function insures that an Extension Dictionary exists, and works on both locations for layer filters
 (vl-load-com)        ; load ActiveX if needed
 (vl-catch-all-apply                                                            ; trap error if no extension dictionary
  (function
   (lambda ()
    (setq objXDict (vla-GetExtensionDictionary                                  ; bind dictionary to variable
                    (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))))))
 (cond (objXDict        ; if the extension dictionary exists
        (or        ; use OR to return T for success
         (rrbI:DeleteAllXRecs objXDict "ACAD_LAYERFILTERS" strKeepWC)           ; pre-2005 layer filters
         (rrbI:DeleteAllXRecs objXDict "AcLyDictionary" strKeepWC)))))          ; 2005 layer filters
(defun rrbI:DeleteAllXRecs  (objXDict dictName strKeepWC / objDict i)
 ;; This function performs the chore of deleting each filer that doesn't match the wildcard
 (vl-catch-all-apply                                                            ; trap errors
  (function
   (lambda ()
    (setq objDict (vla-Item objXDict dictName))                                 ; get layer filters dictionary
    (vlax-for objXRec  objDict                                                  ; loop thru all XRecords in the dictionary
     (cond ((not (and strKeepWC (wcmatch (vla-Get-Name objXRec) strKeepWC)))    ; if deleting all filters, or current doesn't match wildcard
            (setq i (1+ (cond (i)                                               ; increment counter
                              (0))))                                            ; initialize counter
            (vla-Delete objXRec)))))))                                          ; delete filter
 (cond (i (princ (strcat "\n" (itoa i) " filters deleted.")))))                 ; if counter is bound, report number of filters deleted
(defun C:LFD  (/ inpKeep)
 ;; Main command-line function
 (setq inpKeep (getstring
                "\nWildcard mask for filters to keep, or <Enter> to delete all: "))
 (rrbI:LayerFiltersDelete (cond ((/= inpKeep "") inpKeep)))                     ; pass nil to subr if user hit <Enter>
 (princ))        ; clean exit
RobertB is offline   Reply With Quote
Old 2004-06-18, 07:25 PM   #3
vferrara
vferrara appears to be going the right way
Default RE: Need Help Deleting &quot;Named Layer Filters&quot;
Rob:
I have used this code to delete all of the layer filters on our drawings. It works well and is very fast.
;;;;;;Start Of Code
;;;;;;DELETE LAYER FILTERS
(defun C:LFD  ()
 (vl-Load-Com)
 (vl-Catch-All-Apply
  '(lambda ()
    (vla-Remove (vla-GetExtensionDictionary
                 (vla-Get-Layers
                  (vla-Get-ActiveDocument
                   (vlax-Get-Acad-Object))))
                "ACAD_LAYERFILTERS")))
 (princ "\n...")
 (princ "\n...All Layer Filters Have Been Deleted...")
 (princ)
;;;;;;End Of Code
I hope you can find this helpful.
Regards,
Vince
vferrara is offline   Reply With Quote
Old 2004-06-19, 08:47 PM   #4
RobertB
Administrator
RobertB's Avatar
Default
Vince,
Your version of my code is out of date. Please see my post in this thread for a new version.
Old 2004-09-23, 05:55 PM   #5
jetman
jetman is starting their journey
Red face RE: Need Help Deleting &quot;Named Layer Filters&quot;
Free download of CDG Purge developed by the CAD Development Group, LLP will allow you to purge a number of different things from your drawings, including any unused layer filters. Check it out. I use it all the time, so much that I made a tool button for it.
jetman is offline   Reply With Quote
Old 2004-09-28, 06:15 PM   #6
jkramer
jkramer's Avatar
jkramer is glowing brightlyjkramer is glowing brightlyjkramer is glowing brightlyjkramer is glowing brightlyjkramer is glowing brightlyjkramer is glowing brightlyjkramer is glowing brightlyjkramer is glowing brightlyjkramer is glowing brightly
Originally Posted by RobertB
Vince,
Robert,
I have tried using yours and Vince's code and yours gives me some problems (but Vince's works). It asks a question that requires an "<enter> to delete all" and then I have to regen my drawing to get the layer filters to actually go away. (The layerfiltersdelete is an unknown command, so the only way it works is with LFD.)
What is out of date about Vince's, and why is yours not working for me?
Thank you,
Jessica
__________________
Duct tape is like the force, it has a lite side, a dark side, and it holds the Universe togther.
jkramer is offline   Reply With Quote
Old 2004-11-09, 12:16 AM   #7
jpaulsen
jpaulsen's Avatar
jpaulsen is shooting for the starsjpaulsen is shooting for the starsjpaulsen is shooting for the starsjpaulsen is shooting for the starsjpaulsen is shooting for the starsjpaulsen is shooting for the starsjpaulsen is shooting for the starsjpaulsen is shooting for the starsjpaulsen is shooting for the starsjpaulsen is shooting for the starsjpaulsen is shooting for the stars
I did some experimenting with both routines and this is what I found. I tried them in the 2002 versions of LDT / Map with SP1 and LDT / Map 2005 SP1.
The long version works great in 2005 and with limited testing in 2002 it seems to work fine there too.
The short routine will not delete layer filters created in 2005 or layer filters created in 2002 that are recognized by 2005. In other words, if they show up in the layer filter list in 2005 the short version would not delete them.
However, there is still a use for the short version in 2005. I found that in some drawings the layer drop-down list on the Layer toolbar is very slow. Running the short version fixes this problem. For more info on the slow drop-down see this thread.
P.S. I forgot to mention two other things about the long routine. The wild card functionality is case sensitive. Also the routine does not appear to delete any layer filters if one or more were created in that drawing session.
__________________
Jeff Paulsen
CAD Manager
jpaulsen is offline   Reply With Quote
Old 2004-12-17, 07:00 PM   #8
roy.75262
roy.75262 is starting their journey
This routing rocks!. Thank you all.
roy.75262 is offline   Reply With Quote
Old 2005-01-18, 12:43 AM   #9
justin.d.ehart
justin.d.ehart's Avatar
justin.d.ehart is going the right wayjustin.d.ehart is going the right wayjustin.d.ehart is going the right wayjustin.d.ehart is going the right way
  (function
   (lambda ()
  (function
   (lambda ()
So where do I copy and paste this code to run it? In the MNU file? I am sorry I am new to this particular routine!
thanks in advance
-jde
justin.d.ehart is offline   Reply With Quote
Old 2005-01-18, 02:00 PM   #10
jkramer
jkramer's Avatar
Default
You will want to make this a .lsp file and you will need to go into appload to load it up. "LayerFiltersDelete" without the quotes, is what you would type on the command line to make it work.
Good luck, it works like a charm!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Mechanical Structure vs. Layer Groups - Your Input chill AutoCAD Mechanical - General 12 2007-06-18 05:30 PM
ActiveX API - Layer Filter Manipulation ntaylor API Wish List 6 2004-09-09 12:58 AM
Grid Head / Grid lines on separate export layer Griff Revit Architecture - General 1 2004-02-10 11:02 PM
