Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-08, 09:02 PM   #1
pcs
pcs is starting their journey
Default Retrieve Computer ID
Is there a way to get a computer's name from lsp? I've got the user's name with loginname, but I also need the computer's ID.
pcs is offline   Reply With Quote
Old 2004-06-08, 09:54 PM   #2
MarkTheSwampThomas
MarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightly
Default RE: Retrieve Computer ID
I know DosLib will do it.
<qoute>
dos_computer
Returns or sets the computer name of the current system. The name is established at system startup, when it is initialized from the Windows Registry. Changes to the computer name take effect the next time the system is started.
</qoute>
http://www.mcneel.com/doslib.htm
__________________
C3D/LDT2006
I'd rather be using NetBSD
MarkTheSwampThomas is offline   Reply With Quote
Old 2004-06-08, 11:22 PM   #3
stig.madsen
stig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightly
Default
If you don't think it's overkill, you can get some info from the Windows WScript object:
(cond ((setq wscript (vlax-create-object "WScript.Network"))
       (setq pcname (vlax-get-property wscript "ComputerName")
             pcdom  (vlax-get-property wscript "UserDomain")
             pcuser (vlax-get-property wscript "UserName")
       (mapcar 'princ
               (list "\nComputername: "  pcname
                     "\nUser domain:  "  pcdom
                     "\nUser name:    "  pcuser
       (vlax-release-object wscript)
stig.madsen is offline   Reply With Quote
Old 2004-06-08, 11:24 PM   #4
pcs
Thumbs up RE: Retrieve Computer ID
That's exactly what I'm looking for. Thanks Everyone!
Old 2004-06-08, 11:47 PM   #5
stig.madsen
You're welcome.
For some more on scripting objects, you can check out http://www.afralisp.com/lisp/script1.htm
Old 2004-06-09, 12:35 PM   #6
MarkTheSwampThomas
What about this:
(princ (getenv "COMPUTERNAME"))
__________________
C3D/LDT2006
Old 2004-06-09, 01:41 PM   #7
stig.madsen
Mark, you're a genius
why didn't I think of that ..
Old 2004-06-09, 01:55 PM   #8
Mike.Perry
Administrator
Mike.Perry's Avatar
Mike.Perry has disabled reputation
Wink RE: Retrieve Computer ID
Hi Stig
<PublicMockingMode = On>
<PublicMockingMode = Off>
I couldn't be so cruel and publicly mock a LISP Jedi Master wouldn't want to experience the wrath further down the road when I require your help.
Cheers, Mike
__________________
..........MeWhee
Mike.Perry is offline   Reply With Quote
Old 2004-06-09, 01:55 PM   #9
MarkTheSwampThomas
I'm still trying to figure out why I didn't post that in the first place! *grin*
__________________
C3D/LDT2006
Old 2004-06-10, 05:16 AM   #10
sdoman
sdoman's Avatar
sdoman is starting their journey
Default
Stig,
I'm glad you posted how to access the wscript host and also the link to AfraLisp. I wasn't aware how easy it is to write code to access objects outside of AutoCAD. Also at AfraLisp, Kenny shows how to use wscript to get the hard disk serial number, which is something I've been looking for.
Thanks for posting!
sdoman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
License Issue PeterJ Revit Architecture - General 7 2005-06-10 12:55 AM
Big problems with computer memory while rendering JGAbbott Revit - Rendering 15 2004-05-14 12:09 AM
What's in the revit package Nic M. Revit Architecture - General 17 2003-11-25 09:22 AM
New Computer patagoniadave Revit - Hardware & Operating Systems 1 2003-07-30 10:43 PM
