Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-09, 02:50 PM   #1
whdjr
whdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of light
Default Removing duplicate strings in a list
Can someone refresh my memory as to what function is used to remove duplicate strings from a list.
I'm having a brain fart this morning.
Will
whdjr is offline   Reply With Quote
Old 2004-06-09, 03:24 PM   #2
stig.madsen
stig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightly
Default RE: Removing duplicate strings in a list
VL-REMOVE would probably be a good choice.
(vl-remove "hey" '("hey" "this" "is" "a" "bunch" "of" "heys"))
("this" "is" "a" "bunch" "of" "heys")
(vl-remove "heys" '("hey" "this" "is" "a" "bunch" "of" "heys"))
("hey" "this" "is" "a" "bunch" "of")
stig.madsen is offline   Reply With Quote
Old 2004-06-09, 03:30 PM   #3
whdjr
stig,
Thanks for the response. That worked too well I'm afraid.
Let me clarify what I need. I need to delete all the duplicates except one.
list would be :
("hey" "this" "is" "hey" "a" "bunch" "hey" "of" "heys")
remove all "hey" duplicates:
Does that clarify it a bit?
__________________
Good Blockin'
Will DeLoach
AutoCad / ADT 2006
Old 2004-06-09, 04:31 PM   #4
stig.madsen
Default
Hmmm, it clarifies but also makes it a bit more complex. How is the code supposed to know which item to keep? If the first match is to remain then perhaps something like this will do?
(defun removeAllButFirst (item lst / n ll)
  (setq n (cdr (member item lst)))
  (repeat (- (length lst) (length n))
    (setq ll  (cons (car lst) ll)
          lst (cdr lst)))
  (append (reverse ll) (vl-remove item n))
Old 2004-06-09, 05:59 PM   #5
whdjr
I just want it remove all items that are the same except one of them. It doesn't matter which one of them.
__________________
Good Blockin'
Will DeLoach
AutoCad / ADT 2006
Old 2004-06-09, 06:39 PM   #6
MarkTheSwampThomas
MarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightly
I think you want this:
(vl-remove-if predicate-function list)
or:
(vl-remove-if-not predicate-function list)
__________________
C3D/LDT2006
I'd rather be using NetBSD
MarkTheSwampThomas is offline   Reply With Quote
Old 2004-06-09, 07:29 PM   #7
stig.madsen
Default
Ah, no need for order, only removing duplicates:
(defun removeDups (item lst / ll)
  (foreach n lst
    (cond ((equal n item)
           (and (not (member item ll))
                (setq ll (cons n ll))))
          (T (setq ll (cons n ll)))))
  (reverse ll)
Ok, so it keeps the first occurrence like the former
Mark, just being curious: which predicate function would you write for VL-REMOVE-IF to remove duplicates?
Old 2004-06-09, 07:40 PM   #8
whdjr
Thanks stig I'll work that into my code and see how it works.
__________________
Good Blockin'
Will DeLoach
AutoCad / ADT 2006
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Duplicate centroids panderson.60593 AutoCAD Map 3D - General 3 2004-06-09 05:40 PM
List of problems after my first big work with Revit overcaffeined Revit Architecture - General 12 2004-02-04 05:43 AM
