Results 1 to 10 of 14
Thread: Import Page Setup while Publishing
    2006-05
    139
    Default Import Page Setup while Publishing
    Hi all,
    I start the PUBLISH command and then I add the drawings I want to the list. I select the "Plotter named in page setup" option and then I highlight all the drawing in my list, I open the pull down menu under "page setup/3d dwf", select import..., select a dwg file in order to import its page setup information and use it for all the drawings from my publish list that I highlighted and... nothing happens! the page setup info remains the same and nothing is imported. I remember very well that in previous releases of AutoCAD, you could do that and import different page setup information.
    Is there something I am doing wrong? How can this be fixed? Any help would be appreciated.
    Thanks
    Member aletarennee's Avatar
    2006-07
    At Home Now
    35
    Default Re: Import Page Setup while Publishing
    Is the drawing in model space or layout space.
    When you publish did you pick the right tab to match your drawing?
    2006-05
    139
    Quote Originally Posted by aletarennee
    The actual drawing is in model space and the viewport is in paper space as you would expect (if I understood correctly what you asked). As for the right tab to match my drawing, there is only one tab in the drawing I am using as a page setup import. So no need to choose any tab really. And the drawing I am trying to publish has one tab and same paper size as the "template" one.
    Thanks
    2006-07
    At Home Now
    35
    So then when you publish you have the box checked for model space!
    I'm not sure then what is going on?
    100 Club Olaf.Banckaert's Avatar
    2006-02
    Belgium
    133
    Hy,
    Thought I read something about that, try to change the page setup by pressing also the Ctrl or Shift. (If I'm understanding you're question good )
    GreetZzz,
    mE!
    2006-05
    139
    No I dont have the model space box checked because I only want to publish the paper space. And anyway, the page setup info affects only paper space not model space.
    2006-05
    139
    Quote Originally Posted by Olaf.Banckaert
    Hy,
    GreetZzz,
    mE!
    I can give it a try anyway. I have to admit I would be surprised if it worked. It didn't use to be like that in previous releases.
    2006-05
    139
    Hy,
    GreetZzz,
    mE!
    Just tried it and nope it doesn't work (if I tried the right thing that is). But thanks for the try anyway.
    2006-02
    Belgium
    133
    Hy,
    Tried it here from scratch in ADT2006.
    Drawing model + 2 layouts
    Start the PUBLISH commando.
    Now I see the model drawing and the 2 layouts, here is my first question,
    ? In my window I have to delete the layouts I don’t want.
    At the model or a layout I select the PAGE SETUP and Import a Drawing
    I select all the Layouts that needs to have this page setup and then I select them.
    Only in the model drawing it’s not possible to setup the page to the imported drawing
    GreetZzz,
    mE!
    2006-05
    139
    Hy,
    Tried it here from scratch in ADT2006...
    I have tried lots of combinations but nothing works. This is what I have (see attached jpg) and I have just imported a page setup. It doesn't show anywhere and also it doesn't change the existing setups.
    Please note I am using full blown AutoCAD 2007.
  1. Publishing: Corrupt Page Setup?
    By Borgster in forum AutoCAD Plotting
    Last Post: 2012-07-12, 06:12 PM
  2. Import Page Setup Via ObjectDBX
    By brent.burgess in forum VBA/COM Interop
    Last Post: 2009-08-06, 02:15 PM
  3. Page Setup offset when Publishing
    By David van Erk in forum AutoCAD Plotting
    Last Post: 2007-10-23, 10:34 PM
  4. page setup import vlisp
    By David van Erk in forum AutoLISP
    Last Post: 2007-06-20, 08:36 PM
  5. Single sheet publishing thru page setup override
    By aleksandarm in forum AutoCAD Sheet Set Manager
    Last Post: 2007-06-09, 11:42 PM
