Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-10, 04:43 PM   #1
richardl
richardl appears to be going the right way
Default Read-only using Odbx
I currently use this to open drawings using odbx:
(setq DBXOBJ (vla-GetInterfaceObject (vlax-get-acad-object) "ObjectDBX.AxDbDocument"))
(vla-open DBXOBJ filename)
but this opens the file in read/write access (so if the file is already opened it generates an error), is there a way to open a file for access using odbx in read-only mode ?
thanks to all
richardl is offline   Reply With Quote
Old 2004-06-11, 03:00 PM   #2
whdjr
whdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of light
Default RE: Read-only using Odbx
The short answer is no.
Sorry,
__________________
Good Blockin'
Will DeLoach
AutoCad / ADT 2006
whdjr is offline   Reply With Quote
Old 2004-06-11, 04:12 PM   #3
Ed Jobe
Administrator
Ed Jobe's Avatar
Ed Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining star
Default
The short answer is no, since by itself ObjectDbx only open dwg's that are not read-only. But the long answer is yes. I have a cls on the Exchange that handles this error by opening a temp file instead. It also handles dwt's in the same manner by opening a copy as a dwg. See EX001229
__________________
──Ed ──
Ed Jobe is offline   Reply With Quote
Old 2004-06-11, 04:18 PM   #4
richardl
That is the work-around I found, I just tought there was another way.
Thanks
Old 2004-06-11, 05:32 PM   #5
whdjr
Sorry about giving my answer too hastily. I thought we were only talking about Lisp.
__________________
Good Blockin'
Will DeLoach
AutoCad / ADT 2006
Old 2004-06-11, 05:52 PM   #6
Ed Jobe
Administrator
Ed Jobe's Avatar
Default
Oops, I wasn't paying attention to what forum I was in. However, you can duplicate the same functionality in lisp.
__________________
──Ed ──
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
FORUM WILL BE READ ONLY AS OF 5PM 5-26-04 czoog Announcements 5 2004-05-26 04:27 PM
Marking forum read kimheaver Suggestions 0 2004-03-26 11:15 PM
READ ONLY FORUM. beegee Revit - Known Issues & Work-Arounds (Read only) 0 2003-12-13 03:44 AM
Reselect Previous Selection(s) gregcashen Revit Architecture - Tips & Tricks 7 2003-07-19 07:05 AM
Direct Attachments Enabled!!! - PLEASE READ czoog Announcements 3 2003-05-08 09:18 AM
