Welcome, Guest.
| AutoCAD Electrical - General Ask your AutoCAD Electrical questions here! |
Thread Tools | Display Modes |
#1 |
Moderator
Hello, I have a user that changes her command line font and makes it bold and italic. She has made sure this is saved in her profile. Her profile loads automatically. When she opens AutoCAD Electrical 2007 the font is incorrect. When you open the Options dialog box her profile is set to current and the font shows to her preferences. She hits the Set Current button and it then changes her font.
Has anyone else found an issue like this before or know a solution or work around? Thank you for your time, Matt Worland |
#2 | |
#3 | |
Moderator
Sorry for the rant, its been one of those days. Matt |
#4 |
Programming Moderator
It probably could be reset through a VBA or VLISP statement of some sort. It could be added to the startup routine.
I'll see if I can come up with something. But don't hold me to it.
__________________
If you have a technical question, please find the appropriate forum and ask it there. You will get a quicker response from your fellow AUGI members than if you sent it to me via a PM or email. jUSt
#5 |
Does this happen when she runs Vanilla AutoCAD?
__________________
#6 |
Moderator
She does not have vanilla cad.
Thank you Opie but, For now I am using the vla-put-activeprofile function in her acad.lsp. I was hoping for a solution to the problem, not just a work around. I wasn't sure if this was a known issue and had a fix that I could not find. |
#7 | |
Does that work for you?
__________________
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| AutoCad 2007 Files and the "inVISIBLE EIGHTH EYE" | Baldwin_4-6-0 | Revit Architecture - General | 1 | 2006-07-11 04:19 PM |
| Security Flaw in AutoCAD 2007 Password Protection | evan | AutoCAD General | 1 | 2006-06-29 01:23 PM |
| Use DWG to PDF.pc3 from AutoCAD 2007 in AutoCAD 2006? | jbahnsen | AutoCAD Plotting | 1 | 2006-06-21 04:05 PM |
| AutoCAD 2007 Webcasts | Mike.Perry | AutoCAD General | 1 | 2006-06-11 07:20 PM |
| AutoCAD Electrical | cwhitaker | VBA | 1 | 2004-07-03 12:02 AM |
