Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-11, 03:09 PM   #1
richardl
richardl appears to be going the right way
Default loading lisp
is it possible to load a lisp file so that it is accessible to all the currently opened drawings ?
TIA
richardl is offline   Reply With Quote
Old 2004-06-11, 03:12 PM   #2
mjfarrell
mjfarrell appears to be implodingmjfarrell appears to be imploding
Default RE: loading lisp
Look into adding that LISP file to your APPLOAD start-up suite.
mjfarrell is offline   Reply With Quote
Old 2004-06-11, 03:15 PM   #3
richardl
actually it's a routine that I add programmatically add to the start-up, so every subsequent drawings will have that routine loaded but, the drawings that are already opened will not have access to it, is there a way to change that ?
Old 2004-06-11, 03:22 PM   #4
mjfarrell
I believe that it would be best to not attempt this
'progammaticaly'. Add it to the Startup Suite, and then
issue the REINIT command to reinitialize your CAD environment.
Old 2004-06-11, 03:32 PM   #5
stig.madsen
stig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightly
Default
Check out VL-LOAD-ALL in the help files
stig.madsen is offline   Reply With Quote
Old 2004-06-11, 04:41 PM   #6
richardl
that's exactly what I wanted thanks !
__________________
Luc Richard
AUGI forums Moderator
Français
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Leader Lisp Routine that puts in the Elevation denton AutoLISP 8 2008-05-13 05:39 PM
Can I use an Express Tool Command within a lisp? droak AutoLISP 4 2004-06-21 09:16 PM
Changing file attributes with lisp pcs AutoLISP 4 2004-06-11 01:44 PM
Elevation Lisp? gapple AutoLISP 0 2004-06-10 12:25 PM
Need Help w/ a lisp..... smiller AutoLISP 2 2004-06-07 04:17 PM
