Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-16, 09:29 PM   #1
cadconcepts
cadconcepts is starting their journey
Talking List of Blocks in Xref
Hi Everyone-
I need help writing a routine that will build a list of all the blocks in the current drawing including those residing in an xreference. I tried using the tblsearch function but it only returns those blocks in the current drawing. Any help is greatly appreciated. Thanks.
Manuel
cadconcepts is offline   Reply With Quote
Old 2004-06-16, 09:54 PM   #2
MarkTheSwampThomas
MarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightlyMarkTheSwampThomas is glowing brightly
Default RE: List of Blocks in Xref
probably more than you need but ........
(defun get-active-doc ()
 (vla-get-activedocument (vlax-get-acad-object))
(defun get-blk-names2 (/			blk			 layout_blks
					   xref_blks	blks		 blk_name_list
  (vlax-for	blk	(vlax-get-property (get-active-doc) 'Blocks)
	(cond ((= (vlax-get-property blk 'IsLayout) :vlax-true)
		   (setq layout_blks
				  (cons (vlax-get-property blk 'Name) layout_blks)
		  ((= (vlax-get-property blk 'IsXRef) :vlax-true)
		   (setq xref_blks
				  (cons (vlax-get-property blk 'Name) xref_blks)
		  (T (setq blks (cons (vlax-get-property blk 'Name) blks)))
  (setq blk_name_list (list layout_blks xref_blks blks))
(setq blst (get-blk-names2))
__________________
C3D/LDT2006
I'd rather be using NetBSD
MarkTheSwampThomas is offline   Reply With Quote
Old 2004-06-17, 03:20 AM   #3
cadconcepts
Mark-
Thanks for the code. I'll try it out.
Manuel
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Folder or List sdcltd AutoCAD General 4 2004-06-16 08:38 AM
Design Center blocks not scaling properly mjsregister ACA General 3 2004-06-14 10:27 PM
reload xref - layers kca2.69080 ACA General 2 2004-06-02 11:44 PM
List of problems after my first big work with Revit overcaffeined Revit Architecture - General 12 2004-02-04 05:43 AM
