Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-17, 04:10 PM   #1
pcs
pcs is starting their journey
Default Creating .ink shortcuts
Is there a way to create a .ink shortcut with lisp? I am copying network files to a hard drive, and would like to create a shortcut to the network directory programmatically, so it would be easy to save back to the network.
pcs is offline   Reply With Quote
Old 2004-06-17, 05:21 PM   #2
stig.madsen
stig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightly
Default
Thought I could find one in McNeels DosLib library but no luck. Maybe someone here knows the answer to that.
Otherwise, you can utilize the Shell scripting object. The following function creates a shortcut based on these arguments:
target: path of file to make a shortcut to
fname: filebase name of shortcut file (without extension)
path: where to put the shortcut
(defun myShortcut (target fname path / shellObj shortcut)
  (cond ((setq shellObj (vlax-create-object "WScript.Shell"))
         (setq shortcut (vlax-invoke-method
                          shellObj
                          'CreateShortcut
                          (strcat path "\\" fname ".lnk")
         (vlax-put-property shortcut 'TargetPath target)
         (vlax-invoke-method shortcut 'Save)
         (vlax-release-object shortcut)
         (vlax-release-object shellObj)
Of course, you'd probably want some user interface to go with it but it should be basic stuff.
stig.madsen is offline   Reply With Quote
Old 2004-06-17, 07:30 PM   #3
pcs
Default RE: Creating .ink shortcuts
Awesome Stig!
Thanks for all your help.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Project Shortcuts Scott Davis Revit Architecture - Tips & Tricks 12 2004-03-10 11:37 PM
Options Bar: Shortcuts, Floating or Command line Chad Smith Revit Architecture "Original" Wish List (Archived) 14 2003-11-06 12:35 AM
Creating Families Revitlution Revit Architecture - Families 2 2003-10-10 11:59 PM
Simplified Line Keyboard Shortcuts Scott Hopkins Revit Architecture - Tips & Tricks 0 2003-07-24 08:05 PM
Keyboard Shortcuts gregcashen Revit Architecture - Tips & Tricks 14 2003-07-12 01:57 AM
