Welcome, Guest.
| Revit Architecture - Tips & Tricks Got a hot tip? Share it here! |
Thread Tools | Display Modes |
#1 |
Revit Forum Manager
I was preparing a short discussion for our local Revit user group meeting (LUG) to cover detailing with Revit. While not an expert at detailing as an architectural person by any means I have spent a fair amount of time working with acad details and microstation too...the following applies to AutoCAD detail files specifically but most will apply to Microstation as well.
This list was also assembled assuming that "you" are not abandoning the acad files in favor of Revit only based details. These tips will help you keep the details portable and useable in either application. First, stay focused on your goals and choose common ground that helps you achieve them. Avoid statements that start with; "I can't..." We can't..." "I won't...." Font and Dimension Tips:
All for now... Last edited by Steve_Stafford : 2009-06-02 at 08:48 AM. Reason: Added new additions per Brenehan |
#2 |
Thanks Steve - Good Tips!
__________________
Revit 2010 - Autodesk commences "Operation Destroy Revit" |
#3 |
Revit Arch. Wishlist Mgr.
Yeah - super stuff, Steve. Very handy and good to know...
__________________
Wes Macaulay LEED AP Help with the Revit 2010 / Vista + Windows 7 video card compatibility list! Click here and post your results... If it doesn't work, have you submitted a support request about it? If you don't complain, it won't get fixed! |
#4 |
-Phil Last edited by Phil Read : 2004-06-18 at 02:34 AM. |
#5 | |
Revit Forum Manager
#6 |
Hi Steve,
Any Do's / Dont's for hatching? Sharing .pat files between Revit & ACAD? - Jon |
#7 |
Revit Forum Manager
Wow, this is an old thread! Um...avoid really dense patterns or really large patterns, they seem to annoy Revit when importing them as part of a dwg detail file. Revit also doesn't really like those really short lines so if a boundary of a hatch has a really short line segment it may also object to the hatch as being "unbounded".
#8 |
Hi Steve,
I've heard that placing AUtocad details in Detail Component Families will improve performance. Since this is a more cumbersome workflow that does not allow linking of the detail I'm wondering if you can confirm or deny the rumor? Thanks Eric |
#9 |
DON'T put multiple details on one AutoCAD file. One detail per dwg file and view to allow full view cross referencing if required.
DON'T have temporary details and sketches out to the side of your AutoCAD detail file. DO import all your AutoCAD files on a specific Autocad drawing workset. Avoid importing cad files with attached xrefs. |
#10 | |
Revit Forum Manager
I've put cad details in Detail Components as a way to deal with a good many "line as inaccurate direction..." errors and such. One cad detail per detail component and the detail component is placed in a drafting view. The annotation won't come across so it will have to be added to the detail inside Revit. It isn't a pretty solution but it avoids having to spend time resolving mess lines that generate errors when you try to sketch over them with Revit linework or worse...explode the detail. Isolating the cad detail in a detail component traps the errors there...or at least they don't show up in the Review Warnings report in the project. I think the Baylor team did this to remove a good many warnings at one point as a stop gap measure until the details could be "Revitized". Last edited by Steve_Stafford : 2009-06-02 at 08:50 AM. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How are companies using the Sheet Set Manager ? | nhugley | AutoCAD Sheet Set Manager | 47 | 2008-08-01 08:07 PM |
| AEC Details and Revit for Structural Engineering | mmcneil | Revit Architecture - General | 3 | 2004-02-02 09:00 PM |
| Managing details | Jonathon Giebeler | Revit Architecture - General | 12 | 2004-01-30 10:29 AM |
| Revit does ACAD better than ACAD | mikesheehan | Revit Architecture - General | 1 | 2004-01-14 02:47 PM |
| Sick of using old Acad details | Brent | Revit Architecture - Families | 4 | 2003-10-20 09:54 AM |
