Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-18, 05:34 PM   #1
pcs
pcs is starting their journey
Default File dates
I am trying to compare the dates on various files.
I have been using vl-file-systime, which is unreliable, it often returns nil for inexplicable (at least to me) reasons. I now Doslib has a function to pull out a file's date, but is there another way to do it, so I don't have to rely on outside software?
pcs is offline   Reply With Quote
Old 2004-06-18, 06:57 PM   #2
stig.madsen
stig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightly
Default RE: File dates
If you don't want to use either, you could again consult the Windows Scripting Host. But don't forget, that's also "outside software".
File dates accessed by the FileSystemObject are in a 1900-based format that's not easy to convert with AutoLISP. Jon Fleming provides an excellent conversion routine in his ADOLISP Database Library (excellent stuff alltogether). The routine below uses it. Of course you could just compare the raw julian dates it retrieves from the file.
;; Note: Some VL-CATCH-ALL-thingies should be added in strategic places!
(defun fDate (file / fso date)
  (and (not file)(setq file (getfiled "" "" "" 0)))
  (cond ((setq fso (vlax-create-object "Scripting.FilesystemObject"))
         (and (eq :vlax-true (vlax-invoke-method fso 'FileExists file))
              (setq file (vlax-invoke-method fso 'GetFile file))
              (setq date (vlax-get-property file 'DateCreated))
              (setq date (1900BasedJulianToCalender date))
              (vlax-release-object file)
         (vlax-release-object fso)
  date
stig.madsen is offline   Reply With Quote
Old 2004-06-18, 07:04 PM   #3
stig.madsen
Default
By the way, if you need modication or last accessed date instead of creation date - or some other property - then look up the references at http://msdn.microsoft.com/library/default.asp?. Just search for FileSystemObject.
Old 2004-06-23, 01:43 PM   #4
pcs
Thanks for your help, Stig. That will put me where I want to go.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copy Central File B. Strube Revit - Worksharing/Worksets 5 2004-09-24 05:32 PM
Ploting and Publish DWL file trevorh AutoCAD Plotting 2 2004-06-30 10:29 AM
linking a central file to the site plan produces errors JGAbbott Revit - Worksharing/Worksets 2 2004-01-12 01:43 AM
