Results 1 to 8 of 8
Thread: Middle Button OSNAP?
    2001-10
    Waukegan, IL
    52
    Default Middle Button OSNAP?
    We have upgraded to 2005, and I have lost my ability to bring up the OSNAP menu with a single click of my wheel button. I know I can bring it up with ctrl+right button, but I would rather use the middle button.
    Using an intellimouse optical usb, 5 buttons. It is configured as the system device in ACAD.
    2001-12
    St. Louis
    5,421
    Talking Re: Middle Button OSNAP?
    I'm not sure about using a 5button mouse, but, what is your mbuttonpan variable set to?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2001-10
    Waukegan, IL
    52
    Default Re: Middle Button OSNAP?
    Zero. Forgot to mention that.
    13,657
    Hi
    Haven't got AutoCAD 2005 or a 5 button mouse (you lucky thing ), but give the following Technical Document on the Autodesk web site under the Knowledge Base section a try -
    ID: TP00040 - Side Button Mouse Customization for the OSNAP Menu
    ID: TS71373 - Set mouse thumb button to open object snap menu
    ID: TS69028 - Activate object snap menu from Microsoft® IntelliMouse® Explorer mouse
    Hopefully one of the above will point you in the right direction....
    Have a good one, Mike
    2002-06
    Fort Mitchell, KY
    3
    I AM HAVING THE SAME PROB. I DID HAVE THE CAPABILITY BUT LOST IT TODAY FIXING SOME OTHER PROBS. I CAN'T REMEMBER HOW I SET IT TO GET IT TO WORK LIKE THAT. IF YOU HAVE THE ANSWER PLEASE POST IT? THANKS.
    2001-10
    Waukegan, IL
    52
    Well gang:
    It seems the problem is with my specific mouse, or maybe the driver. Other folks in the office have wheel mice which operate off the generic Windows drivers. There is no way of setting the wheel button, and the system seems to interpret the wheel click as a generic middle button click. When the ACAD variable MBUTTONPAN is set to "0", their ACAD responds with the OSNAP menu.
    I have a 5-button Intellimouse, and the loaded driver responds with all sorts of possible assignments for any of the buttons. Except "default". Aye, there's the rub. Can't program it to do function keys either. I'm going to feed this mother to my cat.
    So, for those who have asked, try the following:
    Go into the Mouse folder in the Windows Control Panel, and make sure that your wheel button is set to the system default. If there is nothing to change on the wheel button, then you should be OK. Then go into ACAD and set the MBUTTONPAN variable to "0"
    2001-10
    Waukegan, IL
    52
    Mea Culpa, Bill Gates:
    I found the solution! Set the middle button to "Autoscroll" in the Windows mouse dialogue. This applies only to the Microsoft Intellimouse.
    I could stop if I wanted to awarren's Avatar
    2002-12
    Portland, TN
    212
    If you are using the logitech you can just program it to Ctrl+Shift
  1. Middle mouse button won't Pan
    By powder_special_900 in forum AutoCAD General
    Last Post: 2016-06-23, 01:30 PM
  2. Can't 'middle button pan' when all seems set right
    By kwilson in forum AutoCAD General
    Last Post: 2010-07-02, 07:05 PM
  3. Pan with middle mouse button is gone?
    By gsdaly96 in forum AutoCAD LT - General
    Last Post: 2010-06-08, 11:43 AM
  4. Pan with middle button of mouse
    By s_saldanha in forum AutoCAD Tips & Tricks
    Last Post: 2008-03-04, 12:48 AM
  5. Middle Mouse Button
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2004-10-08, 01:19 PM
