Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-21, 08:06 PM   #1
smiller
smiller's Avatar
smiller is starting their journey
Default Calculate a curve?
Dose anyone have a lisp or a calc. program that will give you curve data by entering 2 items of the curve like the Delta and Chord Length? Any help would be grateful!
__________________
J. Scott Miller, Sr. Engineering Tech. (smiller@danchharner.com)
Danch, Harner & Associates
1643 Commerce Srive
South Bend, IN 46628
(574) 234-4003 FAX (574) 234-4119
smiller is offline   Reply With Quote
Old 2004-06-22, 02:07 AM   #2
paulmcz
paulmcz is going the right waypaulmcz is going the right waypaulmcz is going the right way
Default
...what kind of a curve?
paulmcz is offline   Reply With Quote
Old 2004-06-22, 02:30 PM   #3
smiller
smiller's Avatar
Talking RE: Calculate a curve?
Standard curve......just looking for a cogo calc program that will give you the curve data like if you enter the chord length and the delta it should give you the radius, etc........
__________________
1643 Commerce Srive
Old 2004-06-22, 02:43 PM   #4
peter
Vice President / Director
peter's Avatar
peter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the starspeter is shooting for the stars
Default RE: Calculate a curve?
Maybe?
(defun C:CurveData ()
 (setq sngChordLength (getdist "\nEnter ChordLength: ")
       sngDeltaAngle  (* pi (/ (getdist "\nEnter Delta Angle in Degrees: ") 180.0))
       sngRadius      (/ sngChordLength
                         2.0
                         (sin (/ sngDeltaAngle 2.0))
peter is offline   Reply With Quote
Old 2004-06-22, 02:57 PM   #5
stig.madsen
stig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightly
Default
Oh, a standard curve is a circular curve?
Here's one with chord lenght and arc height:
(defun C:ARCC (/ ch s ch2 ang)
  (and (setq ch (getdist "\nChord length: "))
       (setq s (getdist "\nArc height: "))
       (setq ch2 (/ ch 2.0))
       (mapcar 'princ (list "\nIncluded angle = " (setq ang (* 4.0 (atan (/ s ch2))))
                            " rad (" (* (/ 180.0 pi) ang) " deg)\nRadius = "
                            (/ (+ (expt ch2 2.0) (expt s 2.0)) (* 2.0 s))))
  (princ)
... or to draw it:
(defun C:ARCH (/ p1 p2 s ch2 angr angd rad)
  (cond ((and (setq p1 (getpoint "\nChord start point: "))
              (setq p2 (getpoint p1 "\nChord end point: "))
              (not (equal p1 p2))
              (setq s (getdist
                        (mapcar (function (lambda (m n) (/ (+ m n) 2.0))) p1 p2)
                        "\nHeight of arc: "
         (setq ch2   (/ (distance p1 p2) 2.0)
               angr (* 4.0 (atan (/ s ch2)))
               angd (* (/ 180.0 pi) angr)
               rad  (/ (+ (expt ch2 2.0) (expt s 2.0)) (* 2.0 s))
         (command "ARC" p1 "E" p2 "A" angd)
         (princ (strcat "\nRadius: " (rtos rad)))
  (princ)
stig.madsen is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Exceeded iteration limit when evaluating curve earld AutoCAD 3D (2006 or below) 2 2004-06-03 04:30 PM
Curved Text! Can I automatically curve text around object? Darrel Odom Revit Architecture - General 5 2004-04-29 07:22 PM
Anyone know how to cut out a flat plate and then curve it? Darrel Odom Revit Architecture - General 16 2004-04-15 02:00 PM
Calculate Room Volume Michael Coviello Revit Architecture - Tips & Tricks 1 2003-11-14 12:07 AM
