Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-23, 03:09 PM   #1
Martin P
Martin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the stars
Default filters in lisp/scripts?
Using Revit and Autocad in our office, and have automated some of the tasks we need to do regularly to get the exported DWG Files into a format we need - using a fairly simple lisp routine...
I can do everything apart from filter out the all the "SOLID" hatch for deletion and have to do this manually each time, there isnt a "-filter" to make it usable through lisp, ie it only works in the dialogue box as far as I can tell. Is there a simple way to do this using lisp or scripts - I suspect there probably isnt? Its not hugely important, but I just wondered how you lisp gurus do actually filter stuff out?
__________________
http://www.highplans.co.uk/
Martin P is offline   Reply With Quote
Old 2004-06-23, 04:10 PM   #2
jwanstaett
jwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of light
Default RE: filters in lisp/scripts?
see ssget function in AutoLISP Reference help
this function will let you Select Objects useing a filter
jwanstaett is offline   Reply With Quote
Old 2004-06-23, 08:01 PM   #3
whdjr
whdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of lightwhdjr is a beam of light
Martin,
Yes there are ways to filter out different items in selection sets:
(setq ss (ssget '((0 . "HATCH")(2 . "SOLID"))))
collects all the solid hatches and nothing else. You can use conditionals to filter things using and, or, not, etc. Also you can use wildcards. Review the visual lisp help files for more examples.
__________________
Good Blockin'
Will DeLoach
AutoCad / ADT 2006
whdjr is offline   Reply With Quote
Old 2004-06-23, 09:48 PM   #4
Martin P
excellent, thank you for that and I will have a look at ssget
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Phase filters - more overrides Martin P Revit Architecture "Original" Wish List (Archived) 4 2005-02-10 12:25 AM
Are junk layer filters added? tomdillenbeck AutoCAD General 7 2004-08-31 08:59 PM
Layer filters, anyone? gbrowne AutoCAD LT - General 1 2004-07-20 09:15 PM
Phase filters and linetypes Steve_Stafford Revit Architecture - General 0 2003-06-30 11:30 PM
better selection filters Martin P Revit Architecture "Original" Wish List (Archived) 5 2003-05-02 11:07 PM
