Thread: Migration of Settings to new Release
    Wish List Administration
    2006-03
    1,102
    Default Migration of Settings to new Release
    Summary: Be avle to migrate all settings when installing a new release
    Description: To improve the way new releases are to be updated.
    How Used: With the latest release I had to manually uninstall a few items in order to install the new version. Also many settings had to be manually adjusted again after a version upgrade. This could be done more user friendly, to reduce errors and save more time.
    Feature Affinity: Other
    Submitted By: Maarten Verbunt on October 23, 2006
    2011-08
    4,581
    Exclamation Re: Migration of Settings to new Release
    Product and Feature: Inventor -
    Submitted By: mav on 10/23/2006
    2013-04
    2
    Default Re: Migration of Settings to new Release
    I believe this is already possible. You can export your Application Options from your previous version and then Import them into your newer version.
    2008-09
    Sydney
    The Application Options does only some things, the user interface options can be exported as well. The are other settings life if you are using Vault the columns choosen in each of the views. There are others as well. There are some that need updating based in new file formats. This is something that need highlighting to the CAD administrator to make sure all things are done.
  1. migration
    Last Post: 2012-06-13, 04:14 PM
  2. Migration tool runs even after user has migrated settings
    By hostetterkl in forum AutoCAD General
    Last Post: 2007-06-12, 02:43 PM
  3. CUI Migration?
    By wbs69117950 in forum ACA General
    Last Post: 2007-04-30, 10:07 PM
  4. Release Dates & Release Codenames
    By Buffeldrek in forum Inventor - General
    Last Post: 2006-09-22, 02:19 PM
