Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-06-25, 12:56 AM   #1
patrick.fitzgerald
patrick.fitzgerald is starting their journey
Default Using commands with reactors
Would anybody know a way for a reactor to use a function that has an Autocad command in it eg (command "line" "0,0" "1,1"). I have tried vl-cmdf and this won't work either. I'm using Vers 2004. Any help would be appreciated
patrick.fitzgerald is offline   Reply With Quote
Old 2004-06-25, 01:54 AM   #2
RobertB
Administrator
RobertB's Avatar
RobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the stars
Default
Obviously that is a simplification, as I would use ActiveX to add the line and avoid the command pipeline. What command are you really trying to run?
RobertB is offline   Reply With Quote
Old 2004-06-25, 03:39 AM   #3
patrick.fitzgerald
Default RE: Using commands with reactors
Actually, quite a few. Commands to draw 3dsolids, extrude, revolve as well as command to change the ucs. This function has already been written and I was hoping not to have to re-code using activeX
Old 2004-06-25, 04:30 PM   #4
stig.madsen
stig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightly
Default
From the help files on reactor callback functions: "You cannot call AutoCAD commands using the command function. Also, to access drawing objects, you must use ActiveX functions; entget and entmod are not allowed inside callback functions."
Talking from experience, I would take it literally
stig.madsen is offline   Reply With Quote
Old 2004-06-25, 06:20 PM   #5
RobertB
Administrator
RobertB's Avatar
Default
Yes. A rewrite is in order.
Old 2004-06-28, 03:07 AM   #6
patrick.fitzgerald
I had also come to the re-write conclusion and had started it over the weekend.
The only thing now is to figure out how to determine the XYZ extrusion vectors given three 3Dpoints.
FYI Entget appears to work.. no immediate errors
have not tried entmod
Thanks for the help
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
LSP Commands pbleakley AutoLISP 10 2004-06-04 08:37 AM
