Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2006-12-20, 07:08 PM   #1
mcraven
mcraven's Avatar
mcraven is starting their journey
Default AutoCAD Electrical 2007- Project Manager will not allow me to create a new project
Just installed A2K7e...wanted to go through the basic tutorial...Project Manager will not allow me to create a new project... option is grayed out...fully registered...all of that...what am I missing?
Mike
mcraven is offline   Reply With Quote
Old 2007-01-08, 02:01 AM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default RE: AutoCAD Electrical 2007- Project Manager will not allow me to create a new project
Mike,
Did you get this resolved? If not, let me know and I will investigate it more with some follow up questions. As of this moments, I can not say why that would happen.
Where you able to open the original tutorial through the Help menu?
AUGI is starting a new ATP class Monday, maybe you would like to join?
ATP172-AutoCAD Electrical 2007
Renata
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2008-01-21, 01:55 PM   #3
ulfhjensen
ulfhjensen is infamous around these parts
Default Re: AutoCAD Electrical 2007- Project Manager will not allow me to create a new project
Mike
Mike,
though this post i quite some time after yours, I had the same problem when starting with ACADe 2008. I found that the New Project option was greyed out.
he solution (work-around?) to my problem was to have a drawing open, any drawing. Having a drawing open apparently enables the New Project option. Why this is necessary I do not know. Maybe some of the knowledgeable users of this forum can help here.
Best regards
Ulf Herold-Jensen
ulfhjensen is offline   Reply With Quote
Old 2008-07-08, 02:37 AM   #4
stanwile
stanwile's Avatar
stanwile is infamous around these parts
Smile Re: AutoCAD Electrical 2007- Project Manager will not allow me to create a new project
Ulf Herold is dead-on on this one.
When no drawing is loaded the Project Manager does very little. Also the Tool Pallet disappears.
There is nothing wrong this is just the way Electrical works.
New users sometimes think something is wrong and close Electrical and when it opens they think it works again. Well it works because Electrical opens with a blank drawing open. Just press new and your back to normal.
My guess is the scripts can’t load until a drawing it present.
__________________
Stan Wile
stanwile is offline   Reply With Quote
Old 2008-07-08, 02:40 AM   #5
stanwile
stanwile's Avatar
Just seen this original post is from 12/20/2006. oops....
However even now the same still applies.
__________________
Stan Wile
Old 2008-10-30, 10:48 PM   #6
Mike.Craven
Mike.Craven's Avatar
Mike.Craven is going the right wayMike.Craven is going the right wayMike.Craven is going the right wayMike.Craven is going the right way
and in fact, (now with a few years experience with this truly awesome package from Adesk) the solution was just that....doh...ya hafta have a drawin' open ta create a new projeck....lol
Mike.Craven is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
AutoCAD 2007 - Plots are too light when plotting a project shockman AutoCAD Plotting 9 2008-11-20 03:05 PM
AutoCAD 2007 – Unable to open DST files Trevor_Smith AutoCAD Sheet Set Manager 11 2007-04-24 07:46 AM
Breaking info on AutoCAD 2006 Mike.Perry AutoCAD General 6 2005-07-06 10:25 PM
Relocate project to AutoCAD 0,0 Wes Macaulay Revit Architecture - General 29 2005-06-03 02:48 PM
