Welcome, Guest.
| AutoCAD Electrical - General Ask your AutoCAD Electrical questions here! |
Thread Tools | Display Modes |
#1 |
Manufacturing Moderator
I have 2 stand alone licenses and want to share the user defined catalog entries, components and circuits with both machines, what files do I put in a shared location and what do I modify on the .env file.
any help is appreciated.
__________________
George Sanchez Technical Expert, MICE, DMICE, ICE U.S. CAD San Diego, CA. |
#2 |
We use network licenses here. Yet it would seem that if you add your paths and move your data files to a server, it should work.
Here are the file that are on our server:
Also, when you start a project with one of the schematic drawings open, to check that you are using the correct catalog information and components, when adding a component, the top of the dialog box will read your path. The path location is also inside your project under the properties. These need to be correct. Another place to check in under the project current settings(right click on the project and select the Settings...). There is a ATP172 FastTrack on coping projects that might be of interest. You might need to down load it this week if it is still available before it goes into archives.
__________________
AutoCAD Electrical 2010 (ATP Instructor) soon Autodesk Revit Architecture 2010 AU - 2008 Last edited by RenataP : 2009-03-14 at 06:59 PM. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| County Government Distribution of CAD files | cadguy65 | CAD Management - General | 14 | 2006-10-30 09:29 PM |
| AutoCAD Management/Standards Framework | Richard.Radford | CAD Management - General | 2 | 2006-05-04 11:03 AM |
| Free Utility Application allows multiple DWF files to be opened for markup | Mike.Perry | Software | 0 | 2006-03-14 10:21 PM |
| Missing/Deleted .dwg files...Bug or Virus??? | randyc | Land Desktop - General | 14 | 2005-07-12 06:01 PM |
