Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-07-09, 01:28 AM   #1
sinc
sinc's Avatar
sinc is shooting for the starssinc is shooting for the starssinc is shooting for the starssinc is shooting for the starssinc is shooting for the starssinc is shooting for the starssinc is shooting for the starssinc is shooting for the starssinc is shooting for the starssinc is shooting for the starssinc is shooting for the stars
Default Where is vertical product API documentation?
Where can I find the API documentation for LDD and Civil Design objects (2004 versions)? I'm trying to write something that needs to access point, alignment, and profile data, but the online ActiveX and VBA Documentation seems to only include the base product's objects.
sinc is offline   Reply With Quote
Old 2004-07-09, 01:42 AM   #2
dbroad
dbroad is going the right waydbroad is going the right way
Default RE: Where is vertical product API documentation?
Hello,
I don't have the civil product but would guess that they are in
CHM files in the help directory under the directory where
Autocad resides. That's where the ADT customization stuff is.
dbroad is offline   Reply With Quote
Old 2004-07-09, 05:16 AM   #3
sinc
sinc's Avatar
Default
Thanks. Apparently what I neede is there in the aec-autoreference.chm and land-autoreference.chm files, so I can get to the help I need by typing
(help "land-autoreference")
For some strange reason this help isn't accessable from the default menus, although it's easy enough to add a menu item that can run the above command. It seems strange that the help would be "hidden" in this way, but whatever. I know how to get to it now.
This hidden help resource also told me how to get the objects I need into the VBAIDE object browser by enabling AEC and Land types in Tools->References. Thanks for the pointer. I should be set to start coding now.
Old 2004-07-09, 05:54 AM   #4
dbroad
Default
You're welcome.
Its inconvenient to get to the ADT automation help files also. They
are relatively well written though. Good luck.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Vertical Alignment Editor - Problem in loading application jpaulsen Land Desktop - General 10 2005-10-05 07:53 PM
Adding vertical element to wall family mmulvey Revit Architecture - General 11 2004-04-26 07:47 PM
Mask difference on vertical plane vs. horizontal plane. Skisouth Revit - Rendering 0 2004-04-24 03:08 PM
vertical compound walls and subcategories gnl Revit Architecture - General 0 2003-12-06 08:20 PM
What's in the revit package Nic M. Revit Architecture - General 17 2003-11-25 09:22 AM
