Donnerstag, September 2, 2010
Homepage   |   Suchen   |   Über AUGIde   |   Mein AUGI   |   Jetzt registrieren
Go Back   AUGI Forums > AUGI Technical (English) > General Design > AutoCAD > AutoCAD Support > AutoCAD CUI Menus
 Welcome, Guest.
Login
AutoCAD CUI Menus Create your perfect Workspace.
Reply
Thread Tools Display Modes
Old 2007-03-27, 11:38 PM   #1
jnj1502
jnj1502 is glowing brightlyjnj1502 is glowing brightlyjnj1502 is glowing brightlyjnj1502 is glowing brightlyjnj1502 is glowing brightlyjnj1502 is glowing brightlyjnj1502 is glowing brightlyjnj1502 is glowing brightlyjnj1502 is glowing brightlyjnj1502 is glowing brightlyjnj1502 is glowing brightly
Default Disable the F1 key from opening the Help window?
My left pinkie must need to lose some weight...
Is there a way to disable the F1 key from opening the Help window? I have tried going in to the help menu portion of the ADT cui and deleting the key assignment, but it didn't work.
jnj1502 is offline   Reply With Quote
Old 2007-03-27, 11:51 PM   #2
.T.
.T.'s Avatar
.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial
Default RE: Disable F1 key
One way, and a lot of people do this, is to physically remove the F1 key. It should just pop off with a little gentle persuasion (like a house key to pry with)
__________________
Tim Creary
S&D
DILLIGAF
.T. is offline   Reply With Quote
Old 2007-03-27, 11:56 PM   #3
stusic
Design Visualization Moderator
stusic's Avatar
stusic is a shining starstusic is a shining starstusic is a shining starstusic is a shining starstusic is a shining starstusic is a shining starstusic is a shining starstusic is a shining starstusic is a shining starstusic is a shining starstusic is a shining star
You can always do like I did and physically pop it off the keyboard...
Another alternative would be to assign that key a different function. See the post linked here: Help reassigning that pesky F1 key
Hope this helps!
__________________
Phillip Bradshaw
Animator, Lucid Design Studio
3DS Max 9,
AutoCAD 2008, Adobe Photoshop CS2
A doctor can bury his mistakes but an architect can only advise his clients to plant vines.
- Frank Lloyd Wright
stusic is offline   Reply With Quote
Old 2007-03-28, 03:04 PM   #4
jnj1502
Default RE: Disable the F1 key from opening the Help window?
OK, everything goes according to plan until I hit the Keyboard Shortcuts icon. Then, every time I hit one of the icons, the following message pops up:
"An unhandled exception has occurred in a component in yourapplication. Click continue and application will ignore this error and attempt to continue.
Object reference not set to an instance of an object"
So, when I highlight any of the commands in the command list, the command is not recognized by the CUI and I cannot assign the command to any key.
Running ADT2006 SP1
Old 2007-03-28, 03:44 PM   #5
stusic
stusic's Avatar
Running ADT2006 SP1
In that case, you may consider option #1...
__________________
Phillip Bradshaw
3DS Max 9,
Old 2007-03-28, 03:56 PM   #6
RobertB
Administrator
RobertB's Avatar
RobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the stars
See the attached video. Make sure that Caps Lock is not on when you make the key assignment.
Sorry for the zip file, but the video pixel size is too large to post directly.
RobertB is online now   Reply With Quote
Old 2007-05-31, 10:07 PM   #7
Bear31831
Bear31831 appears to be going the right way
looks like robert B beat me back to you.... You can disable the F1 key.
I did and now my keyboard looks right... (like I care).
Sorry didn't get back sooner.
Joe.
Bear31831 is offline   Reply With Quote
Old 2007-06-01, 02:56 PM   #8
jnj1502
RobertB:
The zip file (which you sent in March? sorry I didn't see it sooner) only had a GIF image, no video. The GIF showed what I SHOULD see when trying to define shortcut keys, but I still get the error message mentioned previously, caps lock or no.
Old 2007-06-05, 09:37 PM   #9
RobertB
Administrator
RobertB's Avatar
The video is a GIF, an animated GIF. The error you mention is probably due to a corrupted CUI file. If you could zip your CUI file and post it here, I might be able to see where the issue is.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Reboot when opening files in anything other than LT2005! hjalmar AutoCAD General 5 2007-03-07 04:23 PM
Window Opening Issue (was stressed.. please help me) ..shaner Revit Architecture - General 13 2007-02-15 08:36 PM
Window not appearing for Opening and Saving commands rjairath AutoCAD General 3 2006-09-14 12:19 AM
error opening a window mtogni Revit Architecture - General 4 2004-11-27 07:30 AM
Add Tab Key in Edit Property Set Data window tomdillenbeck ACA Wish List 0 2004-10-28 10:33 PM
