Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2007-04-03, 07:09 PM   #1
kevin.stlaurent
kevin.stlaurent is starting their journey
Default ACE 2006 - Right click no longer pops up different menu
Used to be that when I right clicked over a selected component I got one shortcut menu with align, attributes, copy components, etc and when I right clicked away from the selected component I would get a different shortcut menu with Move, Copy with base point, etc. As of yesterday when I right click with a component selected I get the first menu no matter where I click. I have not seen any similar problems posted and I have not been able to get it back. Anyone have any ideas? (Acad electrical 2006, no changes from before that I am aware of.)
kevin.stlaurent is offline   Reply With Quote
Old 2007-04-04, 06:29 PM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default RE: Right click differrent
Welcome to AUGI!
As far as I can tell, this is a "glitch" that came with AutoCAD Electrical 2007. Not sure when or how it came about. We all experience this and just deal or cope. Another issue we have come across is that when you select "edit component" from that right mouse click, it will show the other right mouse click shortcut menu. The system seems to be waiting for something. We have to click in a blank spot outside the menu for the system to continue. Not really sure why these exist. They, autodesk, is aware of these issues.
As to seeing this issue addressed? I have noticed that most users tend to search out the discussion forum from Autodesk's website. They have direct contact with those that designed the system. Here is the link, if you would like to check it out.
Found one link that talked about this...
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2007-07-21, 12:16 PM   #3
driesterer
driesterer is infamous around these parts
Default RE: ACE 2006 - Right click no longer pops up different menu
I have upgraded to AutoCAD Electrical 2008 and never had a problem until yesterday. Has anything been done to fix it? It is like losing an old friend.
driesterer is offline   Reply With Quote
Old 2007-07-21, 03:33 PM   #4
driesterer
Thumbs up RE: ACE 2006 - Right click no longer pops up different menu
Good News, I found it again.
I went ti Tools>Options>and under the File tab, select Customization files, then Main Customization files. Change the file to some other .cui file. Then apply it. After it changes to the new file setup, go back and change it back to the .cui file you want or were using before and in my case , I was able to get my shortcut menu when I right click.
Hope this helps.
Dennis
Old 2008-05-29, 02:51 PM   #5
dstnwst
dstnwst is infamous around these parts
Default Re: ACE 2006 - Right click no longer pops up different menu
I have had the same problems running ACE '06, '07 and '08. I just got '09, so we'll see. I just went to Tools>Options>User Preferences>Right Click Options and set it back to how I like it. I also noticed that my user profile changed every now and then and I believe this may have prompted the change to the right click function, but I'm not sure about that.
dstnwst is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Breaking info on AutoCAD 2006 Mike.Perry AutoCAD General 6 2005-07-06 10:25 PM
Remove Copy History from Command Line Right Click Menu jelder AutoCAD Customization 3 2004-11-18 08:38 PM
Short Cut (Right Click) Menu mike.poggemann AutoCAD General 4 2004-10-07 02:48 PM
Right Click Menu Lost Cad4men AutoCAD Customization 2 2004-09-19 09:51 PM
