Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-07-15, 03:32 PM   #1
csgohjmj
csgohjmj is starting their journey
Question Error:EOF after quote on input
Hi;
I have been getting the title error when I run the attached lisp prog in Acad 2000 and above but not Acad R14. I cannot figure out what's wrong and I have noted the error line in the attached file. I hope to get some help. Thanks.
csgoh
csgohjmj is offline   Reply With Quote
Old 2004-07-15, 04:55 PM   #2
stig.madsen
stig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightly
Default
Because READ respects certain characters reserved for lisp evaluations. A quote "'" is read as the function QUOTE:
(read "a") returns the symbol A, but
(read "'a") returns (QUOTE A)
It's the same thing that makes READ capable of returning lisp expressions, as in
(read "(cons 2 4)")
where the left parenthesis signals a lisp expression. Whenever READ bumps into a reserved character it expects an expression to follow. You'll have to check the returned character before using READ.
stig.madsen is offline   Reply With Quote
Old 2004-07-16, 02:02 PM   #3
csgohjmj
Default RE: Error:EOF after quote on input
Hi;
If that's the case, then the prog should not work in Autocad R14 at all but it is working well and there is no problem in R14.
But when tested in 2000 and above it crashes.
Any further enlightenment is much appreciated. Thanks.
csgoh
16-7-04
Old 2004-07-16, 05:50 PM   #4
stig.madsen
Default
That is the case. I can't remember how READ evaluated arguments back in r14 but if you check characters before READ'ing them, it should work in r14 as well.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Input needed... Brian Myers Local Chapters - General 2 2004-07-13 08:08 PM
Can I input a formula in AutoCAD??? jhohman AutoCAD General 4 2004-07-08 12:56 AM
Input Points? nathanw MDT - General 0 2004-07-07 04:12 PM
Revit does calculations on data input Steve_Stafford Revit Architecture - Tips & Tricks 1 2004-04-09 12:29 AM
Soliciting Input for Revit 6 Tutorials Penthesilea Revit Architecture - General 39 2003-07-26 12:01 AM
