Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-07-17, 06:58 AM   #1
LT.Seabee
LT.Seabee's Avatar
LT.Seabee is going the right wayLT.Seabee is going the right way
Question DIMFRAC Variable
Is there another variable that affects the DIMFRAC variable? I have a new routine that sets it to 2 (non-stacked) and yet when I run the routine, it puts it at "0" (stacked)
Any help would be greatly appreciated!
Harvey
LT.Seabee is offline   Reply With Quote
Old 2004-07-19, 04:49 PM   #2
LanceMcHatton
LanceMcHatton's Avatar
LanceMcHatton is a beam of lightLanceMcHatton is a beam of lightLanceMcHatton is a beam of lightLanceMcHatton is a beam of lightLanceMcHatton is a beam of lightLanceMcHatton is a beam of lightLanceMcHatton is a beam of lightLanceMcHatton is a beam of lightLanceMcHatton is a beam of lightLanceMcHatton is a beam of lightLanceMcHatton is a beam of light
Default RE: DIMFRAC Variable
Are you using a Desktop version of AutoCAD? If so, it may automatically change it each time you open a drawing.
Lance
LanceMcHatton is offline   Reply With Quote
Old 2004-07-20, 04:19 PM   #3
LT.Seabee
LT.Seabee's Avatar
Post RE: DIMFRAC Variable
I'm using ADT 3.3, but I'm not opening new drawings, I'm opening existing ones and updating the dimstyle.
Old 2004-07-20, 04:49 PM   #4
stig.madsen
stig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightlystig.madsen is glowing brightly
Default
The only thing I know about DIMFRAC is that DIMLUNIT 1, 2, 3 and 6 affects the display of fractions but it doesn't change the value of DIMFRAC. Besides, I'm sure you'd notice if the dim units changed.
I'd guess it's your routine that messes with the values.
stig.madsen is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
I'd like to see a system variable option for copy - Merged Threads Hippigypsy AutoCAD "Original" Wish List (Archived) 33 2005-01-12 11:51 PM
Reactor to toggle LTScale between MS/PS RobertB AutoLISP 19 2004-06-29 02:39 PM
PEDIT System Variable for Multiple Option ntaylor AutoCAD "Original" Wish List (Archived) 0 2004-06-10 12:59 AM
Variable wall corner treatments Clyne Curtis Revit Architecture - General 1 2004-05-17 11:27 PM
