Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-07-17, 09:50 PM   #1
BCrouse
BCrouse's Avatar
BCrouse is reaching for the moonBCrouse is reaching for the moonBCrouse is reaching for the moonBCrouse is reaching for the moonBCrouse is reaching for the moonBCrouse is reaching for the moonBCrouse is reaching for the moonBCrouse is reaching for the moonBCrouse is reaching for the moonBCrouse is reaching for the moonBCrouse is reaching for the moon
Question PLT file names
Does any know how to eliminate 4 to 5 letters from a PLT file name? This would be helpful when batch plotting files for PLT purpose. Right now we have to go to the file and manually change the name. Here is and example (52226PLAN-CFP01.PLT). When we are done it reads like this (52226CFP01.PLT). Can this be done by a lisp routine?
Thank you,
Brad
__________________
We need men who can dream of things that never were.
John F. Kennedy (1917-1963)
Semper Fi!!!
The Motto of the United States Marine Corps. Latin for always faithful. Faithful to God, Country, Family and the Corps.
Only the Few and the Proud can Understand the meaning of Being a Marine!!!!!!!
Once a Marine, Always a Marine!!
Gulf War Veteran
Operation Restore Hope (Somalia)
USMC
Using ADT 2005
BCrouse is offline   Reply With Quote
Old 2004-07-18, 04:27 PM   #2
mjfarrell
mjfarrell appears to be implodingmjfarrell appears to be imploding
Default RE: PLT file names
Brad, you will want to look at
String-Handling Functions in help and
look at establishing a string pattern
for it to follow when chopping out those
center characters.
mjfarrell is offline   Reply With Quote
Old 2004-07-19, 06:51 PM   #3
BCrouse
BCrouse's Avatar
Exclamation RE: PLT file names
I have done that. We are using Rtext to get the sheet name (52226CFP01). We figured that with the sheet name already established that the PLT name will be the same. But it is not working that way. We are still getting 52226PLAN-CFP01.PLT.
Thank you,
Brad
__________________
Semper Fi!!!
Gulf War Veteran
USMC
Using ADT 2005
Old 2004-07-19, 10:51 PM   #4
RobertB
Administrator
RobertB's Avatar
RobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the stars
Unhappy RE: PLT file names
If I understand you correctly Brad, you want a drawing file named 52226PLAN-CFP01.dwg to write a plot file named 52226CFP01.plt. But you want this to happen with batch plotting (I presume AutoCAD 2005's Publish feature?). I don't think that is possible. Is this in preparing the files for burning to CD or achiving? If so, look for external file management type programs such as Bulk Rename Utility. If it is just for plot queue management, I'm not sure what you can easily do.
RobertB is offline   Reply With Quote
Old 2004-07-19, 10:58 PM   #5
BCrouse
BCrouse's Avatar
Thumbs up RE: PLT file names
Thank you for your assistance with this matter!
Thank oyu,
Brad
__________________
Semper Fi!!!
Gulf War Veteran
USMC
Using ADT 2005
Old 2004-07-21, 10:26 PM   #6
jwanstaett
jwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of lightjwanstaett is a beam of light
??I am use autocad 2002 is the bath plot uitily how part of autocad
Autocad 2002 use a plot uitily in the uitily you can set the name of the plot file
you should be able to set it in Autocad 200 4 or 5
??can you still save a bath plot list
?? if they did not change the format of the bath plot list you can edit it
with a text editer or a autolisp program to change the plot file name
jwanstaett is offline   Reply With Quote
Old 2004-07-22, 01:07 AM   #7
RobertB
Administrator
RobertB's Avatar
Default
Batch plotting was replaced by the Publish command.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copy Central File B. Strube Revit - Worksharing/Worksets 5 2004-09-24 05:32 PM
Is there any replacement for BatchPlot in Autocad 04 and 05? camncad AutoCAD Plotting 12 2004-06-23 07:37 PM
Beware of long file names when exporting... Henry D Revit Architecture - Tips & Tricks 0 2004-02-08 10:02 PM
linking a central file to the site plan produces errors JGAbbott Revit - Worksharing/Worksets 2 2004-01-12 01:43 AM
