Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Programming > AutoLISP
 Welcome, Guest.
Login
AutoLISP AutoLISP or Visual LISP, learn both here!
Reply
Thread Tools Display Modes
Old 2004-07-22, 07:31 PM   #1
msretenovic
msretenovic's Avatar
msretenovic is a beam of lightmsretenovic is a beam of lightmsretenovic is a beam of lightmsretenovic is a beam of lightmsretenovic is a beam of lightmsretenovic is a beam of lightmsretenovic is a beam of lightmsretenovic is a beam of lightmsretenovic is a beam of lightmsretenovic is a beam of lightmsretenovic is a beam of light
Unhappy Detect Read-Only file attribute
Hello all,
I'm writing a routine and have come across a slight snag. I have this code:
(if (not (vl-catch-all-apply 'vla-open (list dbxDoc dwg)))
  (progn
	;;do my stuff here
	(vla-saveas- dbxDoc dwg)
This works really well until I come to a file that is Read-Only . It will do as I expect when the file is Read-Only when someone has it open, but if it's file attribute is Read-Only, it doesn't catch it . Does any know a way around this or how to check to see if a file has a Read-Only attribute ?
TIA
__________________
Michael K. Sretenović
Most folks are about as happy as they make up their minds to be.
-Abraham Lincoln (1809-1865)
-16th president of The United States of America (1861 - 1865)
msretenovic is offline   Reply With Quote
Old 2004-07-22, 07:44 PM   #2
Mike.Perry
Administrator
Mike.Perry's Avatar
Mike.Perry has disabled reputation
Default RE: Detect Read-Only file attribute
Hi Mike
Check out the following article by Stig Madsen -
Scripting objects
Way over my head but I'm pretty sure you can/could achieve what you're after using the methods described in the article.
Have a good one, Mike
__________________
..........MeWhee
Mike.Perry is offline   Reply With Quote
Old 2004-07-22, 07:54 PM   #3
RobertB
Administrator
RobertB's Avatar
RobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the starsRobertB is shooting for the stars
Default
Here is a simple method too:
(defun IsRO (fileN / fileH)
 (cond ((setq fileH (open fileN "a"))
        (close fileH)))
 (not fileH))
RobertB is offline   Reply With Quote
Old 2004-07-22, 08:49 PM   #4
msretenovic
Robert,
That is exactly what I was looking for . So simple, yet so effective .
Thanks
__________________
Old 2004-07-23, 01:02 AM   #5
RobertB
Administrator
RobertB's Avatar
Default
Glad I could help!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Editing attribute layer hbisco AutoCAD General 8 2005-05-13 03:53 PM
Copy Central File B. Strube Revit - Worksharing/Worksets 5 2004-09-24 05:32 PM
Is there any replacement for BatchPlot in Autocad 04 and 05? camncad AutoCAD Plotting 12 2004-06-23 07:37 PM
