Results 1 to 6 of 6
Thread: Error element is slightly off axis
    2006-07
    Melbourne, Australia
    38
    Default Error element is slightly off axis
    How do you tell revit that a line/wall is meant to be slightly off axis & you want it that way?
    Cause if you straighten it out it's not bisecting the angle properly anymore and tiny little errors are appearing when using the line to mirror stuff about the line.
    If would be nice if you could tag the review warnings as "Ignore it, Yes i know, It's meant to be that way - please don't straighten / fix this particular wall/line etc."
    2006-03
    London, UK
    810
    Default Re: Error element is slightly off axis
    Quote Originally Posted by sonya
    Press tab once you're dragging the endpoint and you have more freedom to move it. You can cycle through snaps like this as well. When all else fails, I use detail lines to get a good snap point and then snap to that. Delete the construction lines afterwards.
    100 Club Wesley's Avatar
    2003-04
    Sydney, Australia
    119
    I agree - we have this submitted as a wishlist item. Without it you eventually get a review warnings list with 100 of items in it that you know about, don't want to change, but affect performance simply by being monitored in the list. Frustrating...
    2005-12
    213
    Quote Originally Posted by Wesley
    I agree to a certain extent, but I am weary about it. The reason is that you will always have someone in the office who would ignore everything just because they don't want to take the time to address and correct some of the mistakes that need to be done or they just get frustrated because they don't understand the warning and isn't able to "fix" it on the 1st try. Good idea, but I would suggest to limit the "ignore it" to something like the off axis deal, "items have duplicate mark", and maybe "structural element is attached to non-structural element." Or we would just have to do more managing on our end to make sure that only one person can use the "ignore it" button.
    All AUGI, all the time clog boy's Avatar
    2006-12
    Probably near a PC.
    843
    I had instances in which Revit wasn't able to create a roof or sweep, but displayed the outline exactly as I intended. That's where an 'ignore it, continue anyway' button would come in handy.
    As for overuse: people would learn when and how to use it, once they find out 'lazy' ignores just lead to more hassle.
    2005-12
    213
    Quote Originally Posted by bram.weinreder
    ...As for overuse: people would learn when and how to use it, once they find out 'lazy' ignores just lead to more hassle.
    Here's hoping!
  1. 2013: Beam/Brace Slightly off Axis Warning
    By david_peterson in forum Revit Structure - General
    Last Post: 2013-11-13, 09:56 PM
  2. slightly off axis
    By wadeshuey in forum Revit Architecture - General
    Last Post: 2010-09-21, 04:10 PM
  3. Slightly Off Axis
    By sthedens in forum Revit Architecture - General
    Last Post: 2010-08-12, 07:14 PM
  4. Script / API to clean up “Line slightly off axis”
    By brenehan in forum Revit Architecture - General
    Last Post: 2009-06-13, 02:52 PM
  5. Correcting Lines which are slightly off the axis
    By harilalmn in forum VBA/COM Interop
    Last Post: 2009-02-05, 06:07 PM
