Welcome, Guest.
| AutoLISP AutoLISP or Visual LISP, learn both here! |
Thread Tools | Display Modes |
#1 |
Does anyone have available a routine that will automatically lock all paperspace viewports upon opening a drawing file, regardless of the quantity or whether the drawing was previously saved in model space.
I would like to load it in acad2004doc.lsp, as this file loads from our server, across all cad stations. Thanks, Jerry |
#2 |
Add this to the end of your lisp file....
(defun vplock (yesno / ss lock x obj)
(vl-load-com)
(if (setq ss (ssget "X" '((0 . "VIEWPORT")(-4 . "/=")(69 . 1))))
(progn
(if (= "y" yesno) (setq lock :vlax-true)(setq lock :vlax-false))
(setq x 0)
(while (< x (sslength ss))
(setq obj (vlax-ename->vla-object (ssname ss x)))
(vla-put-displaylocked obj lock)
(setq x (1+ x))
(princ)
(vplock "y")
#3 |
Vice President / Director
Here are my versions
You may have to change the method of selecting the objects with the acaddoc.lsp. If you get errors from these let me know. Peter Jamtgaard Code:
(defun C:LockVP (/ intCount ssSelections)
(setq ssSelections (ssget "x" (list (cons 0 "VIEWPORT"))))
(repeat (setq intCount (sslength SSET))
(vla-put-DisplayLocked (vlax-ename->vla-object
(ssname ssSelections
(setq intCount (1- intCOunt))))
:vlax-true
(prin1)
(defun C:UnlockVP (/ intCount ssSelections)
:vlax-false
(prin1)
#4 |
Here is one that setsthe vp to red when locked & green when unlocked.
(defun c:vpunlockall () ; 06/07/04
(vl-load-com)
(vlax-for lay
(vla-get-layouts
(vla-get-activedocument
(vlax-get-acad-object)
(if (eq :vlax-false (vla-get-modeltype lay))
(vlax-for ent (vla-get-block lay) ; for each ent in layout
(if (= (vla-get-objectname ent) "AcDbViewport")
(progn
(vla-put-displaylocked ent :vlax-false)
(vla-put-color ent 3); 3 green
(defun c:vplockall () ; 06/07/04
(vl-load-com)
(vlax-for lay
(vla-get-layouts
(progn
(vla-put-displaylocked ent :vlax-true)
(vla-put-color ent 1);1 red
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Different scales for lines in different viewports | slaidlaw | AutoCAD General | 17 | 2005-04-28 07:05 PM |
| Locking a drawing | BCrouse | AutoCAD "Original" Wish List (Archived) | 10 | 2004-09-30 01:51 PM |
| My sheets keep locking up | Jmickledesign | ACA General | 4 | 2004-06-11 03:11 PM |
| Revit program philosophy on locking & unlocking | Henry D | Revit Architecture - General | 6 | 2004-01-20 11:15 PM |
| More locking options for non-model elements | gregcashen | Revit Architecture "Original" Wish List (Archived) | 0 | 2003-05-15 10:51 PM |
