Donnerstag, September 2, 2010
Homepage   |   Suchen   |   Über AUGIde   |   Mein AUGI   |   Jetzt registrieren
Go Back   AUGI Forums > AUGI Technical (English) > CAD Management > AutoCAD Customization
 Welcome, Guest.
Login
AutoCAD Customization Learn to create custom Hatches / Linetypes, macros, scripts...
Reply
Thread Tools Display Modes
Old 2007-06-15, 03:03 PM   #1
Spanky
Spanky's Avatar
Spanky has a bright futureSpanky has a bright futureSpanky has a bright futureSpanky has a bright futureSpanky has a bright futureSpanky has a bright future
Default Change the F1 function key to perform some other function
How do you change the "help" shortcut key command, f1, to something else. Or even just delete the shortcut all together. I would like replace this command with delete or erase. In doing this I would then be able to just hit f1 if I wanted to delete something.
Responses Are Encouraged
Spanky is offline   Reply With Quote
Old 2007-06-15, 11:50 PM   #2
.T.
.T.'s Avatar
.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial.T. is celestial
Default RE: Shortcut Key Customization
Levi, what the heck are you doing in an Inventor forum? You'll get a response quicker if you post in an Autocad forum.
Have a look at THIS THREAD and see if it helps you out...There are other threads on this if you use the search facility, also.
__________________
Tim Creary
S&D
DILLIGAF
.T. is offline   Reply With Quote
Old 2007-06-19, 07:36 PM   #3
jaberwok
Certified AUGI Addict
jaberwok's Avatar
jaberwok is celestialjaberwok is celestialjaberwok is celestialjaberwok is celestialjaberwok is celestialjaberwok is celestialjaberwok is celestialjaberwok is celestialjaberwok is celestialjaberwok is celestialjaberwok is celestial
Default RE: Change the F1 function key
Why not just hit the "Delete" key? It's the same size.
Although you can override it in acad, remember that F1=Help is a Windows function.
__________________
John B
AutoCAD 2010 / AutoCAD 2008 ...... jUSt AutoCAD since 1984. ~RDAPAS~ ~CWC RRB~ ~S & H~ 124K.
"Indecision is the key to flexibility"
jaberwok is online now   Reply With Quote
Old 2007-11-27, 09:35 PM   #4
Spanky
Spanky's Avatar
Default Re: Change the F1 function key
I keep my pointer finger on the escape key most of the time when im drafting. Its easier to hit the f1 key than it is to hit the delete key. I have had this configuration for some time now and i really like it. i highly suggest you try it.
__________________
Never miss a good chance to make the right decision.
A rough beginning doesn't negate a smooth end.
Old 2007-11-27, 11:46 PM   #5
jaberwok
jaberwok's Avatar
The thread that Tim linked to should help you, especially if you follow the links within the thread.
I guess other people must use ESC a lot more than I do.
Nostalgia/trivia - early versions of acad did not use the ESC key in the same way; it was necessary to type ^c (just like in a macro).
Users complained because ESC to escape from a command was becoming standard usage in other programmes.
__________________
John B
Old 2007-11-28, 12:02 PM   #6
BrenBren
Wish List Manager
BrenBren's Avatar
BrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestial
Nostalgia/trivia - early versions of acad did not use the ESC key in the same way; it was necessary to type ^c (just like in a script).
FWIW, I use escape all the time. I also still have help on my F1 key - there is a big enough gap between esc and F1 on my keyboard it just doesn't cause an problem for me. But, this does show that it is nice to have flexibility in how you set up your workstation
__________________
Brenda Richardson
Wish List Manager
BrenBren is offline   Reply With Quote
Old 2007-11-28, 03:28 PM   #7
Richard.Kent
Richard.Kent's Avatar
Richard.Kent is reaching for the moonRichard.Kent is reaching for the moonRichard.Kent is reaching for the moonRichard.Kent is reaching for the moonRichard.Kent is reaching for the moonRichard.Kent is reaching for the moonRichard.Kent is reaching for the moonRichard.Kent is reaching for the moonRichard.Kent is reaching for the moonRichard.Kent is reaching for the moonRichard.Kent is reaching for the moon
Default Re: Change the F1 function key to perform some other function
http://lynn.blogs.com/lynn_allens_bl...st_autoca.html
And turn the CapsLock off when hitting the F1 key while in the CUI.
__________________
My wife says "Willie Nelson still looks the same amount of old."
Richard.Kent is online now   Reply With Quote
Old 2007-11-28, 04:14 PM   #8
BrenBren
Wish List Manager
BrenBren's Avatar
That link, along with others, is included here
However, this is an old thread, and as far as I can tell, the OP has already solved his problem.
__________________
Brenda Richardson
Wish List Manager
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Setup a Hardware Schedule using a Revit Key Schedule Jeffrey McGrew Revit - Tutorials 25 2010-04-20 07:53 PM
Layer key overrides RobertB AMEP General 15 2006-02-21 09:47 PM
Enhanced attribute editor, make a change - unable to Cancel or use Esc key ckluver AutoCAD General 3 2005-12-20 10:48 PM
Change function of Help button [F1] RWESTON AutoCAD Customization 4 2005-12-13 06:39 PM
Description Key Manager gcoronado Survey - General 3 2005-11-10 05:06 PM
