Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2007-06-27, 09:10 PM   #1
timothyjturner
timothyjturner's Avatar
timothyjturner is going the right waytimothyjturner is going the right waytimothyjturner is going the right waytimothyjturner is going the right waytimothyjturner is going the right way
Default Couple of Problems
Hello,
We have a couple of guys in our department with AutoCAD Electrical 2008 installed and they are having some problems...
1) One guy can not get the project manager window to disappear. Everytime he hits escape, clicks a line, etc. the project manager window will reappear.
2) One guy can not get dialog boxes to pop up. His FILEDIA variable is set to 1, so that is not the problem.
__________________
Timothy J. Turner
Electrical Designer
McGill AirClean LLC
Email: TTURNER@McGillAirClean.com
timothyjturner is offline   Reply With Quote
Old 2007-06-27, 09:17 PM   #2
BrenBren
Wish List Manager
BrenBren's Avatar
BrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestialBrenBren is celestial
Default RE: Couple of Problems
Originally Posted by timothyjturner
Hello,
What about CMDDIA? for the second guy?
I'm also gonna move this to the Electrical forum.
__________________
Brenda Richardson
Wish List Manager
BrenBren is offline   Reply With Quote
Old 2007-06-27, 09:28 PM   #3
timothyjturner
Actually, for the second guy, i just got it to start working... I have no idea how.... I tried to set CMDDIA a little earlier and it did not recognize that variable...
So I guess the main problem is with the first guy now. Thanks.
__________________
Timothy J. Turner
Electrical Designer
McGill AirClean LLC
Old 2007-06-29, 06:28 PM   #4
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
[quote=timothyjturner]Hello,
QUOTE]
Hi,
Did you check to see if the tool pallet was locked? Located in lower right corner. see picture.
Are other windows reappear, for example if you open the properties window?
Or does it happen when he right clicks, then it would be a menu issue.
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2007-07-02, 03:48 PM   #5
timothyjturner
[quote=RenataP]
Hello,
Hi,
The tool pallet should not be locked, because he is able to drag and move the project manager around the screen. No other windows are appearing when this happens. I do not think this happens when he right clicks... its usually when he clicks a line or hits the escape key.
__________________
Timothy J. Turner
Electrical Designer
McGill AirClean LLC
Old 2007-07-02, 06:49 PM   #6
RenataP
RenataP's Avatar
Sorry to say, yet my favorite saying is that it must be a glitch.
Not having 2008 yet, my suggestion would be to leave it on and use the following property settings: Allow Anchor, Anchor Left, Auto-Hide. That way it is out of the way, but not always reappearing.
Let us know if you find a solution. Sorry for not being able to find one.
__________________
AU - 2008
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
License Manager problems jarkko.rauvanlahti Revit Architecture - General 12 2005-10-19 02:34 AM
"Possibly" some fixes to CUI issues / problems on the way. Mike.Perry AutoCAD CUI Menus 1 2005-08-24 10:05 PM
Problems with Solprof output. adamn AutoCAD 3D (2006 or below) 2 2005-08-16 03:54 PM
Big Time problems Plotting barathd Revit - Plotting/Printing/Exporting 1 2004-09-28 07:28 PM
List of problems after my first big work with Revit overcaffeined Revit Architecture - General 12 2004-02-04 05:43 AM
