Welcome, Guest.
| AutoLISP AutoLISP or Visual LISP, learn both here! |
Thread Tools | Display Modes |
#1 |
Need simple autolisp to add parethesis (...text...) to front and back of text string.
#2 |
Moderator
Here's a routine that does it...
From the lisp guild many moons ago, sorry but I don't remember who wrote it. Code:
(defun c:be (/ CNT ss pre suf ents val new) (vl-load-com) (setq CNT 0 ss (ssget '((-4 . "<or") (0 . "TEXT") (0 . "MTEXT") (-4 . "OR>")) ) ) (if ss (progn (setq pre (getstring "\nPrefix to add [Enter to skip]: ") suf (getstring "\nSuffix to add [Enter to skip]: ") ) (repeat (sslength ss) (setq ents (entget (ssname ss CNT)) val (cdr (assoc 1 ents)) new (strcat pre val suf) ) (setq ents (subst (cons 1 new) (assoc 1 ents) ents ) ) (entmod ents) (setq CNT (1+ CNT)) ) ) (prompt "\nNothing Selected.") ) (princ) ) ;;end defun Last edited by Mike.Perry : 2006-04-24 at 01:26 PM. Reason: [CODE] tags added. |
#3 |
This is an interesting lisp.....I was trying to figure out when this would be good to have... Can you give an example of when this would come in handy..
__________________
Bbapties Using Vanilla Acad 2005 Last edited by RobertB : 2004-08-02 at 10:51 PM. Reason: Better title |
#4 |
Vice President / Director
Just for another way of doing it (with vl commands)
Peter Jamtgaard Code:
(defun C:TextPS (/ intCount objSelection strPrefix strSuffix ssSelections)
(princ "\nSelect text and mtext: ")
(setq ssSelections (ssget (list (cons 0 "TEXT,MTEXT")))
strPrefix (getstring "\nEnter Prefix: " 't)
strSuffix (getstring "\nEnter Suffix: " 't)
(repeat (setq intCount (sslength ssSelections))
(setq intCount (1- intCount)
objSelection (vlax-ename->vla-object
(ssname ssSelections intCount)
(vla-put-textstring objSelection
(strcat
strPrefix
(vla-get-textstring objSelection)
strSuffix
(prin1)
#5 | |
Moderator
And thanks for the updated version, Peter. Less code is always better in my opinion. Celie Last edited by RobertB : 2004-08-02 at 10:51 PM. Reason: Better title |
#6 |
"APTXT" from Cadalyst is a dialog based routine that allows you to add prefixes or suffixes to any text with many options. I use it at least once a week.
Tip1527A: DDAPTXT.LSP Append to Text (c)June 1999, Scott A. Matthews added support for MTEXT & DIMENSION's March 2003, Tom Beauford Code:
;Tip1527A: DDAPTXT.LSP Append to Text (c)June 1999, Scott A. Matthews
;added support for MTEXT & DIMENSION's March 2003, Tom Beauford
(defun c:aptxt ( / cnt ent elist prefix ss suffix value) ; begin append text command
(aptxt_setup) ; run setup
(if (< (setq dcl_id (load_dialog "ddaptxt.dcl")) 0) ; if dialog file is not loaded
(exit) ; then exit
) ; end if
(while (< 2 what_next) ; continue until ok or cancel is picked
(if (not (new_dialog "ddaptxt" dcl_id)) ; if dialog box is not loaded
(exit) ; then exit
) ; end if
; start dialog box setup
(if (/= ss nil) ; if objects have been selected
(set_tile "select_txt" (rtos (sslength ss) 2 0)) ; then display number of objects
) ;end if
(if (/= prefix nil) ; if prefix is set
(set_tile "prefix_eb" prefix) ; then display prefix
) ; end if
(if (= prefix_space 1) ; if prefix is set
(set_tile "prefix_tb" "1") ; then display prefix
) ; end if
(if (= suffix_space 1) ; if prefix is set
(set_tile "suffix_tb" "1") ; then display prefix
) ; end if
(if (/= suffix nil) ; if suffix is set
(set_tile "suffix_eb" suffix) ; then display suffix
) ; end if
; end dialog box setup
; start actions for tiles
(action_tile "accept" "(setq key $key)(done_dialog 0)")
(action_tile "cancel" "(setq key $key)(done_dialog 0)")
(action_tile "select_pb" "(setq key $key)(done_dialog 3)")
(action_tile "prefix_eb" "(setq prefix $value)")
(action_tile "prefix_tb" "(setq prefix_space (atoi $value))")
(action_tile "suffix_eb" "(setq suffix $value)")
(action_tile "suffix_tb" "(setq suffix_space (atoi $value))")
; end actions for tiles
(setq what_next (start_dialog)) ; throw up the dialog
(cond
((= key "accept") ; if ok button is picked
(if (= ss nil) ; if no text objects have been selected
(progn ; then
(setq what_next 5) ; continue with append text command
(alert "No text objects selected.") ; prompt user to select objects
) ; end progn
(while (setq ent (ssname ss cnt)) ; while there are still text entities to process
(setq cnt (1+ cnt) ; add one to counter
elist (entget ent) ; get entity list
old (dxf 1 elist) ; get text value
new old ; set new same as old
) ; end setq
(if (= new "")(setq new "<>")) ; if DIMENSION
(if (/= prefix nil) ; if text prefix is set
(if (= prefix_space 1) ; if space after prefix is on
(setq new (strcat prefix " " new)) ; then add the prefix plus a space to text string
(setq new (strcat prefix new)) ; else add the prefix to text string
) ; end if
) ; end if
(if (/= suffix nil) ; if text prefix is set
(if (= suffix_space 1) ; if space before suffix is on
(setq new (strcat new " " suffix)) ; then add the suffix plus a space to text string
(setq new (strcat new suffix)) ; else add the suffix to text string
) ; end if
) ; end if
(entmod (subst (cons 1 new) (cons 1 old) elist)) ; update text with new value
) ; end while
) ; end if
) ; end if
((= key "select_pb") ; if select button is picked
; (setq ss (ssget (list (cons 0 "TEXT")))) ; create a selection set of text objects
(setq ss (ssget (list (cons 0 "TEXT,MTEXT,DIMENSION")))) ; create a selection set of text objects
) ; end if
) ; end cond
) ; end while
(aptxt_reset) ; run reset
(defun aptxt_err (s) ; begin error function
(if (not (member s '("console break" "Function canceled" "Invalid selection"))) ; if command is aborted
(princ (strcat "\nError: " s)) ; then prompt user
) ; end if
(command ".undo" "b") ; undo back to mark
) ; end error function
(defun aptxt_reset () ; begin reset function
(setvar "cmdecho" cmde) ; reset command echo
(setq *error* olderr) ; reset error function to old error function
(princ "\n \n \n") ; clean up command prompt
(princ) ; clean up command prompt
) ; end reset function
(defun aptxt_setup () ; begin setup function
(setq olderr *error* *error* aptxt_err ; set error function to append text's error function
cmde (getvar "cmdecho") ; get current value of command echo
cnt 0 ; set counter to zero
prefix_space 1
suffix_space 1
what_next 5 ; continue main function until ok or cancel is picked
) ; end setq
(setvar "cmdecho" 0) ; set command echo to zero
(command ".undo" "m") ; set undo mark in drawing database
) ; end setup function
(defun dxf (list_itn ent_list) ; begin dxf function
(cdr (assoc list_itn ent_list)) ; get value of item from entity list
) ; end dxf function
(princ)
//Tip1527B: DDAPTXT.DCL Append to Text (c)1999, Scott A. Matthews
ddaptxt : dialog {
label = "Append Text";
: row {
: button {
key = "select_pb";
label = "Select <";
mnemonic = "S";
} // end select button
: concatenation {
: text_part {
value = "Objects Found:";
width = 13;
} // end text part
: text_part {
key = "select_txt";
value = "0";
width = 5; } // end text part
} // end text concatenation
} // end row
spacer_1;
: edit_box {
key = "prefix_eb";
label = "Prefix";
mnemonic = "P";
} // end prefix edit box
: toggle {
key = "prefix_tb";
label = "Space after prefix?";
mnemonic = "a";
} // end add space toggle button
: toggle {
key = "suffix_tb";
label = "Space before suffix?";
mnemonic = "b";
: edit_box {
key = "suffix_eb";
label = "Suffix";
mnemonic = "u";
} // end suffix edit box
spacer_1;
ok_cancel;
spacer_1;
} // end main dialog box
__________________
Tom Beauford P.S.M. - Map 2010 +Eagle Point on XP Design Analysis - Leon County Public Works/Engineering 2280 Miccosukee Rd. Tallahassee, FL 32308-5310 Ph# (850)606-1516 Last edited by RobertB : 2004-08-02 at 10:52 PM. Reason: Better title |
#7 |
Here's mine if you're interested. I don't know who originally wrote it but it automatically provides ( and ) without having to type them in.
(defun c:addpar ()
(command "UNDO" "M")
(setq B 0)
(setq C 0)
(princ "\nSelect text entities to change: ")
(setq SSET (ssget))
(setq PRE "(")
(setq SUF ")")
(while (= B 0)
(setq ENT (ssname SSET C))
(if (= ENT nil)
(setq B 1)
(progn
(setq ED (entget ENT))
(setq TYPE1 (cdr (assoc 0 ED)))
(if (= TYPE1 "TEXT")
(setq D 0)
(if (= TYPE1 "ATTDEF")
(setq D 0)
(progn
(setq SSET (ssdel ENT SSET))
(setq c (- c 1))
(if (= D 0)
(progn
(setq STRING (cdr (assoc 1 ED)))
(setq STRING (strcat PRE STRING SUF))
(setq ED (subst (cons 1 STRING) (assoc 1 ED) ED))
(entmod ED)
(setq D 1)
(setq C (+ C 1))
(setvar "cmdecho" 1)
(princ)
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Export linetype definitions | bbapties | AutoCAD Customization | 7 | 2006-08-15 08:29 PM |
| Text Note Improvements | bclarch | Revit Architecture "Original" Wish List (Archived) | 33 | 2004-08-05 05:16 PM |
| Text Recognition | waltham845 | Raster Design - General | 2 | 2004-07-10 03:43 AM |
| Bold text for shape fonts with named plot styles? | sinc | AutoCAD General | 1 | 2004-06-29 09:45 AM |
| Stairs/Ramps - Up/Down text and arrows | Steve_Stafford | Revit - Known Issues & Work-Arounds (Read only) | 11 | 2003-11-08 09:50 PM |
