Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2007-07-05, 11:04 PM   #1
jhorn
jhorn is infamous around these parts
Default Panel Schedule modifications
Hello all, new to the forum.
I'm developing a panel schedule and have allotted 6 208volt slots on a 120/208v panel with the remaining slots single phase, 120v.
I want the 208v single phase breaker assignments to be at the top of the panel but the Panel Schedule program defaults some at the top and bottom; plus the circuit sequence is off.
I'm having to revise per my layout via 'edit attributes'.
I'm sure there is a better/quicker way to fix?
jhorn is offline   Reply With Quote
Old 2007-07-06, 09:59 PM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default RE: Panel Schedule modifications
Welcome to the forum!
What software version are you using?
I have not heard of "Panel Schedule program" inside AutoCAD Electrical 2007.
Sounds interesting...how does it work.
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2007-07-10, 10:56 PM   #3
jhorn
Hi,
I'm using MEP 2008. I contacted an Autodesk instructor about this as well.
__________________
Jim Horn, Electrical Designer
QCI Marine Offshore, LLC
Pascagoula, MS
Autodesk MEP 2008, ABS Building Systems 2007
Old 2007-07-16, 06:24 PM   #4
RenataP
RenataP's Avatar
Originally Posted by jhorn
Hi,
Sounds like an other program I should look into. Sorry I can not help with your question.
Do you like working with this program? We use AutoCAD Electrical for all our panel work.
__________________
AU - 2008
Old 2007-07-18, 09:29 PM   #5
bhoerth
bhoerth's Avatar
bhoerth is infamous around these parts
Smile RE: Panel Schedule modifications
This may help
Go to the Electrical pull down menu.
Electrical Settings
Electrical Preference
Circuiting Tab
Numbering Section - Group using number of poles
When I made a change in here for the Prefix I had to redo the panels for the changes to take effect. So if you are far along you may want to keep this in mind for the next project.
I hope this helps.
bhoerth is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Setup a Hardware Schedule using a Revit Key Schedule Jeffrey McGrew Revit - Tutorials 21 2009-03-10 05:04 PM
Panel Schedule Style ordengate AMEP General 6 2007-04-03 05:58 PM
Is there a way to have DB's link to a schedule table? dzatto Dynamic Blocks - Technical 6 2007-03-06 11:20 PM
Problems displaying Electrical Panel Schedule revans.89349 AMEP General 2 2005-06-21 04:46 PM
Electrical Panel Schedule neb1998 Revit Architecture - General 3 2005-06-01 01:13 AM
