Results 1 to 8 of 8
Thread: How to convert any spline to pline?
    2007-08
    6
    Default How to convert any spline to pline?
    How to convert any spline to pline? Anyone can help me? Thanks very much in advanced.
    2003-11
    277
    Default Re: How to convert any spline to pline?
    Hi ttaahhhh,
    Test this code
    (defun massoc (key alist / x nlist)          ; Jaysen Long
      (foreach x alist
        (if
          (eq key (car x))
          (setq nlist (cons (cdr x) nlist))
      (reverse nlist)
    (defun c:test (/ cmt len sp ss sse)
      (if
        (setq ss (car (entsel "\nSelect an object spline")))
        (progn
          (setq sse (entget ss))
          (setq sp (massoc 10 sse))
          (setq len (length sp))
          (setq cmt 0)
          (repeat
    	len
    	(command "_pline" (nth cmt sp)(nth (1+ cmt) sp) "")
    	(setq cmt (1+ cmt))
    	) ; repeat
          (command "_erase" ss "")
          )   ; progn
        (alert "\nInvalid selected object,try again")
        )     ; if
      (princ)
    Quote Originally Posted by ttaahhhh View Post
    2005-06
    CORDOBA-ARGENTINA
    276
    Other way to do .
    (defun C:spltopl ()
     (while (not (and
                  (setq lstSelection   (entsel "\nSelect Spline: "))
                  (setq sngSegment     (getdist "\nGet Segment Length: "))
                  (setq objSelection   (vlax-ename->vla-object (car
    lstSelection)))
                  (wcmatch (vla-get-objectname objSelection)
    "AcDb2dPolyline,AcDbPolyline,AcDbLine,AcDbArc,AcDbSpline"
      (princ "\nError please select again: ")
     (setq sngLength   (vlax-curve-getDIstAtParam objSelection
                        (vlax-curve-getEndParam objSelection)
           sngDistance 0.0
     (vl-cmdf "._pline" (vlax-curve-getpointatDist objSelection 0.0))  (repeat (fix (/ sngLength sngSegment))
      (vl-cmdf (vlax-curve-getpointatDist objSelection sngDistance))
      (setq sngDistance (+ sngDistance sngSegment))
     (vl-cmdf (vlax-curve-getPointAtParam objSelection
    2007-08
    6
    2006-04
    470
    You could use explode on the spline, and pedit to join all segments.
    2004-08
    Iron Station, NC
    3,198
    Quote Originally Posted by aaronic_abacus View Post
    you cant explode a spline. but you can use the express tool flatten, and it will convert it with out a problem.
    2006-04
    470
    oops, I was looking at a polyline with spline applied by pedit and not one made with the spline command.
    I wonder what the diiference is between the two.
    2007-03
    57
  1. Spline to Pline or Lines
    By CADdancer in forum AutoLISP
    Last Post: 2013-07-26, 12:41 PM
  2. Convert a spline to a pline
    Last Post: 2012-07-18, 02:53 AM
  3. PLINE to Spline
    By vijaybaskergundla in forum VBA/COM Interop
    Last Post: 2008-09-06, 10:05 AM
  4. Spline to Pline
    By csiress in forum AutoLISP
    Last Post: 2007-11-17, 02:57 AM
  5. spline to pline
    By ftjaa in forum AutoCAD General
    Last Post: 2005-02-18, 02:48 PM
