Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Pushing Out acad 2008 through Active Directory
    2006-05
    New Jersey
    147
    Default Pushing Out acad 2008 through Active Directory
    I'm trying to push out A2008 through Active directory. I can't seem to get it to push out all custom settings. (ie: search paths). The base install does happen, just no custom settings.
    I push out the acad.msi in the admin folder as well as the acad-....mst file also in the admin folder.
    Anyone else run into this problem? Am i doing something wrong?
    Earth
    9,803
    Default Re: Pushing Out acad 2008 through Active Directory
    Are you simply calling the .MSI file in your GP?
    R.K. McSwain | CAD Panacea |
    2006-05
    New Jersey
    147
    Calling acad.MSI as well as .MST that was generated after the deployment.
    2006-05
    New Jersey
    147
    Problem solved. I recreated the deployment, and now it works.
    2006-05
    New Jersey
    147
    UPDATE:
    I can now get all the search paths, acad opens fine, but i get several error messages in the process. Anyone seen these messages?
    See Attachment.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,089
    I've seen the first and third message. Unfortunately, I don't know the solution for either one.
    The second one looks to be a DirectX issue. You may need to verify the installation of DirectX or reinstall it on the affected machine.
    2002-01
    jUSt Here (a lot)
    9,089
    Quote Originally Posted by dxarhoulakos View Post
    UPDATE:
    See Attachment.
    Here's one article, "Error: Unable to load profile file" for the first issue. It may fix the third one as well. I just haven't tested it.
    Earth
    9,803
    UPDATE:
    Are you also installing all the prerequisites beforehand? (vba, flash, directx, xml, etc)
    You can't just install the "acad.msi" and expect everything to work OK.
    2006-05
    New Jersey
    147
    i thought everythign is being installed as part of the deployment?
    wont the msi point to the ini files, which direct everything else.....and mst will load all sustom settings
    this is exactly how i rolled out 2K6.
    Earth
    9,803
    That is not my understanding. We were using a BAT file to install 2008 and had to call each msi file separately.
    2k8 deployments are different.
  1. AutoCAD LT and Active Directory
    By jonathan.landeros in forum Networks
    Last Post: 2015-06-29, 07:49 AM
  2. Replies: 11
    Last Post: 2011-01-27, 04:33 PM
  3. EXCLUDE, GROUP and Active Directory
    By ShawnF in forum Networks
    Last Post: 2008-12-11, 01:44 PM
  4. Revit quarrying active directory
    By Dave Lewis in forum Revit - API
    Last Post: 2007-02-05, 10:11 PM
  5. Revit quarrying active directory
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2007-02-05, 09:31 PM
