You can also use these functions. GetRegAppBase can be modified to return whatever you need to determine which app is running.
Public Function GetAppPath() As String
'returns path of acad.exe for current desktop app
'you may need to append a backslash when concatenating text
Dim strPath As String
strPath = ThisDrawing.Application.Path
GetAppPath = strPath
End Function
Public Function GetAppRegBase() As String
Dim str As String
str = GetAppPath
Select Case str
Case Is = "C:\Program Files\Autodesk Map 3D 2005"
GetAppRegBase = "Software\Autodesk\AutoCAD\R16.1\ACAD-302:409\"
Case Is = "C:\Program Files\Autodesk Building Systems 2007"
GetAppRegBase = "Software\Autodesk\AutoCAD\R17.0\ACAD-5006:409\"
Case Else
GetAppRegBase = ""
End Select
End Function
