Hi ALL,
I know the following phrase or similar:
(menucmd "M=$(edtime, $(getvar, date),MO/DD/YY HH:MM:SS)")
But how to show a real timer - I mean the timer showing the live second digit.
Can anyone help?
Ke
Hi ALL,
Can anyone help?
Ke
Hi ke.li,
test my code
Code:; ddc is stand for Display Digital Clock ; Design by : Adesu <Ade Suharna> ; Email : mteybid@yuasabattery.co.id ; Homepage : http://www.yuasa-battery.co.id ; Create : 15 April 2006 ; Program no.: 0357/04/2006 ; Edit by : Adesu 29/08/2007 1). (defun c:ddc (/ txs stx loc1 th el1 sse1 dhr loc1a el4 loc2 el2 sse2 dmin loc2a el5 loc3 el3 sse3 dsec year month date loc4 th1 str4 el6 start end time hour minute second ) (setq txs (getvar "textstyle")) ; for get textstyle current (setq stx "Arial") (if (= (tblsearch "style" "arial") nil) ; 1) (command "_style" stx stx "0" "1" "0" "n" "n" "n") ) ; if (setvar "textstyle" stx) ; for set new textstyle (setq loc1 (getpoint "\nClick any location for put clock<0,0,0>: ")) (if (= loc1 nil)(setq loc1 '(0 0 0))) (setq th 5) (command "_text" loc1 th "" "00" 0) (setq el1 (entlast)) (setq sse1 (entget el1)) (setq dhr (cdr (assoc 1 sse1))) (setq loc1a (list (+ (car loc1) 8.5)(cadr loc1)(caddr loc1))) (command "_text" loc1a th "" ":" 0) (setq el4 (entlast)) (setq loc2 (list (+ (car loc1) 10)(cadr loc1)(caddr loc1))) (command "_text" loc2 th "" "00" 0) (setq el2 (entlast)) (setq sse2 (entget el2)) (setq dmin (cdr (assoc 1 sse2))) (setq loc2a (list (+ (car loc1) 18.5)(cadr loc1)(caddr loc1))) (command "_text" loc2a th "" ":" 0) (setq el5 (entlast)) (setq loc3 (list (+ (car loc2) 10)(cadr loc2)(caddr loc2))) (command "_text" loc3 th "" "00" 0) (setq el3 (entlast)) (setq sse3 (entget el3)) (setq dsec (cdr (assoc 1 sse3))) (setq year (substr (rtos (getvar "CDATE") 2 6) 1 4)) (setq month (substr (rtos (getvar "CDATE") 2 6) 5 2)) (setq date (substr (rtos (getvar "CDATE") 2 6) 7 2)) (setq loc4 (polar loc1 (* pi 1.5) 5)) (setq th1 2.5) (cond ((= month "01")(setq month "January")) ((= month "02")(setq month "February")) ((= month "03")(setq month "March")) ((= month "04")(setq month "April")) ((= month "05")(setq month "May")) ((= month "06")(setq month "June")) ((= month "07")(setq month "July")) ((= month "08")(setq month "August")) ((= month "09")(setq month "September")) ((= month "10")(setq month "October")) ((= month "11")(setq month "November")) ((= month "12")(setq month "December")) ) ; cond (setq str4 (strcat date "-" month "-" year)) (command "_text" loc4 th1 "" str4 0) (setq el6 (entlast)) (command "_zoom" "e") ; 1). (setq start 0) (setq end (getdist "\nEnter value in second for finish<1000>: ")) (if (= end nil)(setq end 1000)) (while (< start end) (setq time (rtos (getvar "CDATE") 2 6)) (setq hour (substr time 10 2)) (setq minute (substr time 12 2)) (setq second (substr time 14 2)) (if (/= dsec second) (progn (entdel el3) (command "_text" loc3 th "" second 0) (setq el3 (entlast)) ) ; progn ) ; if (if (/= dmin minute) (progn (entdel el2) (command "_text" loc2 th "" minute 0) (setq el2 (entlast)) ) ; progn ) ; if (if (/= dhr hour) (progn (entdel el1) (command "_text" loc1 th "" hour 0) (setq el1 (entlast)) ) ; progn ) ; if (setq start (1+ start)) ) ; while (setq lst (list el1 el2 el3 el4 el5 el6)) (foreach x lst (entdel x) ) ; foreach (setvar "textstyle" txs) (princ) )
Ade, how is anyone supposed to get any work done while this is running?
Ke, why not just display the OS clock? Why force AutoCAD to use CPU cycles for something that is already there in the OS?
R. Robert Bell
Design Technology Manager
Stantec
yahoo widgets anyone?
I have a nice neon clock running in the corner
of my cad session.
R. Robert Bell
Stantec
