Thursday, July 29, 2010
Go Back   AUGI Forums > AUGI Technical (English) > General Design > AutoCAD > AutoCAD Support > AutoCAD General
 Welcome, Guest.
Login
AutoCAD General Ask your AutoCAD 2010 or below "general" questions here!
Reply
Thread Tools Display Modes
Old 2007-10-02, 10:14 PM   #1
cblackford
cblackford's Avatar
cblackford has a bright futurecblackford has a bright futurecblackford has a bright futurecblackford has a bright futurecblackford has a bright futurecblackford has a bright future
Default ucsfollow not sticking in modelspace
Has anyone else had a problem with ucsfollow not sticking in modelspace since upgrading to 2008? IE: Set ucsfollow to 1, save and exit, go back in and it's reverted back to zero. We don't have any startup rotines running that would cause this so I am a bit of a loss.
Chuck
cblackford is offline   Reply With Quote
Old 2007-10-03, 01:47 PM   #2
jbayne
jbayne's Avatar
jbayne is glowing brightlyjbayne is glowing brightlyjbayne is glowing brightlyjbayne is glowing brightlyjbayne is glowing brightlyjbayne is glowing brightlyjbayne is glowing brightlyjbayne is glowing brightlyjbayne is glowing brightlyjbayne is glowing brightlyjbayne is glowing brightly
Default Re: ucsfollow not sticking in modelspace
Chuck,
Just off the top of my head it sounds as though it is changing with a profile load. The icon on the desktop has a profile that it loads when you start software. The default is /p "AutoCAD" . If you create a different profile with the change already made then make sure icon properties is set to load that profile.
I am not sure this is the culprit just one of the things you can check.
Jim
__________________
Jim Bayne
Sheets Architects P.A.
jim@sheetsarchitects.com
Fat, drunk and stupid is no way to go through life, son
Dean Vernon Wormer (Animal House)
jbayne is offline   Reply With Quote
Old 2007-10-03, 03:31 PM   #3
cblackford
cblackford's Avatar
Originally Posted by jbayne View Post
Chuck,
Jim
Thanks for the reply Jim. Unfortunately we're not loading any profiles. Also, the UCSfollow variable is susposed to be save in the file. I can't figure it out.
Old 2007-10-03, 06:06 PM   #4
cblackford
cblackford's Avatar
For the benefit of anyone doing a future search on this issue. Here is the reply from Autodesk support on this issue:
Chuck,
I can confirm that this is a known issue in our 2008 software. The problem is scheduled to fixed in the next major release of AutoCAD.
Unfortunately, I do not have a workaround that will maintain the UCSFOLLOW value in model space between drawing sessions.
Please let me know if you have any questions.
Best Regards,
Autodesk Support Team
Old 2007-10-04, 12:25 PM   #5
ccowgill
ccowgill's Avatar
ccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the starsccowgill is shooting for the stars
Chuck,
Best Regards,
that sounds alot like the reply we got in regards to rotating blocks with attributes using the properties palette
__________________
Christopher T. Cowgill, P.E.
WIGHTMAN JONES, INC.
CONSULTING ENGINEERS & LAND SURVEYORS
AutoCAD 2011/2010 v3 64
XP Pro 64bit SP2 (Home)
Windows 7 Ultimate 64bit (Work)
ccowgill is offline   Reply With Quote
Old 2007-10-11, 04:21 PM   #6
ivooomen
ivooomen is infamous around these parts
I have the same problem.
When i change ucsfollow setting from 0 to 1. And i leave modelspace to paperspace, when i come back in model. The setting is back on 0! Very frustreating. I have tride to change the acadvar.ini file. I can change this but, in the first drawing it is 1. But when i change model/paper again its back to 0.
Is this a bug? Or a setting in cad?
ivooomen is offline   Reply With Quote
Old 2007-10-11, 11:02 PM   #7
cblackford
cblackford's Avatar
It's a known bug in 2008 that did not get fixed with SP1.
Old 2008-03-12, 07:14 PM   #8
CadDog
CadDog's Avatar
CadDog has a bright futureCadDog has a bright futureCadDog has a bright futureCadDog has a bright futureCadDog has a bright futureCadDog has a bright futureCadDog has a bright future
For now I have my AcadDoc.lsp run and change it to "1" when a drawing is open...
Fixed...
Thanks because I did not notice it and
no user told me they were having any problems with it...
(setvar "ucsfollow" 1)
Also, i have used a program
which along with changing space
also resets ltscale along with a few other things
that AutoCAD have always forgot to do...
We don't use those s2s tabs at the bottom of views. We use this TT for years.
Here is a look.
(defun c:TT ()(Setvar "cmdecho" 0);1=arch 2=Eng 4=MM 6=Meters
;(if (=(getvar "userr3")0)(progn(Alert "\nYou Need to run DDS\n")(exit)))
(if (=(getvar "userr3")0)(progn (load "DH-dds2") (c:dds2) ))
(if (= (getvar "tilemode") 1) ;if your in Model Space
(progn
(cond
;((and (= (getvar "USERR3") 0))(progn (command "userr3" "1")))
((and (= (getvar "USERI1") 0)) ; imperial
(progn
(command "ltscale" "1")
(command "setvar" "psltscale" "1")
(command "textsize" ddsth)
(command "DIMSCALE" "1")
(command "DimAssoc" "1")
(if (=(getvar "userr5")1)(progn (command "insunits" "1")))
(if (=(getvar "userr5")2)(progn (command "insunits" "1")))
(if (=(getvar "userr5")4)(progn (command "insunits" "4")))
(if (=(getvar "userr5")6)(progn (command "insunits" "4"))); Added for 2006 insertion blocks
((and (= (getvar "USERI1") 2)) ; metric Milli
(progn
(command "ltscale" "25.4")
(command "textsize" "3")
(command "dimscale" "1")))
);end first cond
(command "tilemode" "0" "DimAssoc" "1" )(setvar "ucsfollow" 1) ; Switch to Paper Space
);end first progn
(progn
(cond
((/= (getvar "USERR2") 0)(command "textsize"(getvar "USERR2") "dimscale"(getvar "USERR4")))
((and (= (getvar "USERR1") 0))(progn (command "userr1" "1"))))
(command "ltscale" (getvar "USERR1")"dimlfac" "1" "tilemode" "1" "DimAssoc" "1")(setvar "ucsfollow" 1)
(if (=(getvar "userr5")6)(progn (command "insunits" "4"))); Switch to Model Space
);end second cond
)(Setvar "cmdecho" 1)(princ))
BTW: the DH-DDS2 is another program which set all the user vers on the drawing which this program uses to reset each and everytime a user open and/or moves from s2s...
__________________
Jesse
aka CadDog © 1994
All is Well until It Fails
Remember, that what you teach me here you are also teaching others...
CadDog is offline   Reply With Quote
Old 2008-06-20, 08:04 PM   #9
tatriest
tatriest is reaching for the moontatriest is reaching for the moontatriest is reaching for the moontatriest is reaching for the moontatriest is reaching for the moontatriest is reaching for the moontatriest is reaching for the moontatriest is reaching for the moontatriest is reaching for the moontatriest is reaching for the moontatriest is reaching for the moon
I modified the 'Z axis' button to look like this:
^C^Cucsfollow;1;_ucs _z
Terry
tatriest is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Convert DWG's done in Modelspace only to DWG's using both Paperspace and Modelspace Jonnydubya AutoCAD General 9 2007-01-10 09:28 AM
SheetSetPlaceHolder Fields not working with Modelspace View tmarshall AutoCAD Sheet Set Manager 2 2006-08-21 11:19 PM
Model tab vs Modelspace via Layout tab? wallnerme AutoCAD General 4 2006-07-17 09:13 AM
ModelSpace to PaperSpace Coord Translation colgateg AutoLISP 1 2006-05-23 10:16 PM
Link a object in Modelspace to a Field in Paperspace Spectrefish AutoCAD Fields 3 2005-02-04 10:21 PM
