Tuesday, February 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > Geospatial > AutoCAD Map 3D Support > AutoCAD Map 3D - General
 Welcome, Guest.
Login
AutoCAD Map 3D - General Ask your AutoCAD Map 3D 2009 or below questions here!
Reply
Thread Tools Display Modes
Old 2007-10-23, 06:16 PM   #1
Ed Jobe
Administrator
Ed Jobe's Avatar
Ed Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining starEd Jobe is a shining star
Default Workaround for custom view scale bug
I found a bug in MAP 3D 2008. To reproduce it, maximize Map, turn of the task pane (or undock) and select the View Scale dropdown in the status bar, select Custom. The resulting dialog will appear halfway off the screen. Since it doesn't have a titlebar, you can't drag it back into view. This has been reported. Here are 3 workarounds.
  1. Make sure that the taskpane is displayed and docked before you select this.
  2. Make sure that Map is restored down and the right border is far enough away from the right edge of the monitor before selecting this.
  3. After selecting, use Alt+SPACEBAR>M or RTCLK+M and then use the keyboard arrow keys to move the dialog to the left. Unfortunately, the position is not retained.
__________________
──Ed ──
Ed Jobe is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
changing plot scale settings from decimal to inches msanders.85217 AutoCAD Customization 2 2007-10-22 08:23 PM
View Range - Associated Level MTristram Revit Architecture - General 0 2007-09-09 11:58 PM
View Scale parameter in families ekurbatov Revit Architecture "Original" Wish List (Archived) 10 2007-08-07 06:29 AM
View Title family and View Scale Adam Mac Revit Architecture - Families 4 2007-01-23 11:39 PM
Scale of a View Limitation Chad Smith Revit Architecture - General 15 2003-09-26 01:10 AM
