Welcome, Guest.
| Revit - Hardware & Operating Systems Ask your hardware and operating system questions here! |
Thread Tools | Display Modes |
#1 |
Hi Phil
Laptop HP NW9440 Centrino Duo CPU T7400 @ 2.16GHz Nvidia Quadro FX 1500m Couple of things... AllowPressAndDrag - not in ini file (mine anyway) Attached results but not complete, came to an end with the 'enter interactive mode' button while trying to export views 18 opening and loading the custom template 15 creating the floors levels and grids. 48 creating a group of walls and doors 80 modifying the group by adding a curtain wall 33 creating the exterior curtain wall 17 creating the sections 16 changing the curtain wall panel type 15 creating a perspective view 5 changing the curtain wall panel pleat 40 changing the levels height 94 update group to maintain level to level height 90 render a 3d view 14 export different views
__________________
Simon Whitbread Revit Specialist, Auckland, New Zealand bim-bs.blogspot.com "The distance the shotput goes, depends upon the effort that you PUT INTO IT" Last edited by Simon.Whitbread : 2007-11-26 at 06:41 PM. |
#2 |
Had a look into why it wasn't working...
17 opening and loading the custom template 15 creating the floors levels and grids. 47 creating a group of walls and doors 80 modifying the group by adding a curtain wall 34 creating the exterior curtain wall 16 creating the sections 16 changing the curtain wall panel type 15 creating a perspective view 5 changing the curtain wall panel pleat 41 changing the levels height 94 update group to maintain level to level height 91 render a 3d view 246 export different views 8 save the project -pc running XP only, so you can benchmark against a virgin machine ( I can't account for all the software cr4p loaded though )
__________________
Simon Whitbread Revit Specialist, Auckland, New Zealand bim-bs.blogspot.com "The distance the shotput goes, depends upon the effort that you PUT INTO IT" |
#3 |
AMD 64X2 4.4Ghz, 2GB RAM, 10K HD's,8600 nVidia, WinXP 32:
12, opening and loading the custom template 10, creating the floors levels and grids. 46, creating a group of walls and doors 91, modifying the group by adding a curtain wall 33, creating the exterior curtain wall 13, creating the sections 17, changing the curtain wall panel type 15, creating a perspective view 5, changing the curtain wall panel pleat 46, changing the levels height 103, update group to maintain level to level height 89, render a 3d view 277,export different views 8,save the project ---------------------------------- Total : 765 Last edited by GuyR : 2007-11-26 at 11:40 PM. |
#4 |
Thanks to those who worked in developing this benchmark - should be very useful in determining hardware needs!
Desktop PC WinXP Pro Core2Duo x6800 2.93 4GB RAM ATI FireGL 3400 9 opening and loading the custom template 7 creating the floors levels and grids. 33 creating a group of walls and doors 64 modifying the group by adding a curtain wall 34 creating the exterior curtain wall 9 creating the sections 12 changing the curtain wall panel type 9 creating a perspective view 4 changing the curtain wall panel pleat 30 changing the levels height 73 update group to maintain level to level height 72 render a 3d view 181 export different views 6 save the project 543 TOTAL
__________________
Daniel Friesen I could? I don't think so... |
#5 |
Intel Core2 @ 2.66GHz, 3.5GB RAM, WinXP Pro SP2, NVIDIA Quadro FX 3500
8 opening and loading the custom template 7 creating the floors levels and grids. 34 creating a group of walls and doors 62 modifying the group by adding a curtain wall 25 creating the exterior curtain wall 9 creating the sections 12 changing the curtain wall panel type 11 creating a perspective view 4 changing the curtain wall panel pleat 31 changing the levels height 75 update group to maintain level to level height 79 render a 3d view 193 export different views 6 save the project 556 Total
__________________
#6 |
Now on my home machine I have run a few tests, and noticed some interesting things. The first launch of Revit does seem to be slower (15 seconds vs 14 in my case) but not as much as I was expecting. And running iTunes does have an impact, amounting to about a 5% reduction over the full benchmark. Perhaps not much, but not trivial either. And the saddest part, my home machine is a dog!
14 opening and loading the custom template 11 creating the floors levels and grids. 47 creating a group of walls and doors 109 modifying the group by adding a curtain wall 33 creating the exterior curtain wall 13 creating the sections 17 changing the curtain wall panel type 15 creating a perspective view 5 changing the curtain wall panel pleat 47 changing the levels height 125 update group to maintain level to level height 91 render a 3d view 279 export different views 9 save the project 815 Total That puts me at 5% slower than some folks running a VM on a MacBook, and a whopping 80% slower than the high end MacPro in BootCamp! And that was my fastest run, no other apps open, second launch, etc. AMD Athlon 64X2 4200+, 2G RAM, 7200rpm sATA HD, ATI FireGL v3300, WinXP 32, OpenGL On Gordon |
#7 |
Revit Arch. Wishlist Mgr.
11 opening and loading the custom template
8 creating the floors levels and grids. 37 creating a group of walls and doors 68 modifying the group by adding a curtain wall 30 creating the exterior curtain wall 10 creating the sections 13 changing the curtain wall panel type 12 creating a perspective view 4 changing the curtain wall panel pleat 35 changing the levels height 82 update group to maintain level to level height 50 render a 3d view 243 export different views 8 save the project 611 Total WinXP Pro SP2 Q6600 Core 2 Quad 2.4Ghz, Intel DG33BU 2Gb RAM 667 Mhz To check your own CPU and memory specs, download the attached zipfile.
__________________
Wes Macaulay LEED AP Craven|Huston|Powers Architects Revit Architecture 2011 x64 | Win7 x64 | ATI Radeon 4670 |
#8 |
11 creating the floors levels and grids. 48 creating a group of walls and doors 90 modifying the group by adding a curtain wall 56 creating the exterior curtain wall 13 creating the sections 19 changing the curtain wall panel type 18 creating a perspective view 6 changing the curtain wall panel pleat 47 changing the levels height 110 update group to maintain level to level height 91 render a 3d view 347 export different views 11 save the project 881 Total Dell Inspiron 6400/E1505 WinXP Pro SP2 T2500 2.0 Ghz Core Duo CPU 2Gb of 533Mhz RAM Once SP3 comes out we ought to run these benchmarks again! My first score was 907, and after turning off some services I don't need, dropped the score to 881.
__________________
Wes Macaulay LEED AP Craven|Huston|Powers Architects Revit Architecture 2011 x64 | Win7 x64 | ATI Radeon 4670 Last edited by Wes Macaulay : 2007-12-06 at 02:27 PM. |
#9 |
My Work Comp
I want more power Anybody with a QX9770 or Xenon out there 9 opening and loading the custom template 7 creating the floors levels and grids. 41 creating a group of walls and doors 79 modifying the group by adding a curtain wall 27 creating the exterior curtain wall 10 creating the sections 15 changing the curtain wall panel type 12 creating a perspective view 5 changing the curtain wall panel pleat 40 changing the levels height 95 update group to maintain level to level height 85 render a 3d view 254 export different views 6 save the project 685 Total Win Xp SP2 Core 2 duo 6400@2.13 GHz 2 GB Ram |
#10 |
NavisWorks Moderator
Curiously I tried the test on 2 different machines with the same specs, the only difference is one is running XP with 4gb of ram and the other is running XP64 with 12gb of ram. Surprisingly the 32 bit machine won
I've had mixed results in other tests I've run, some tasks are much faster on 64 and some are slower....God please let Revit 09 be 64 bit! |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Setup a Hardware Schedule using a Revit Key Schedule | Jeffrey McGrew | Revit - Tutorials | 25 | 2010-04-20 07:53 PM |
| Journal Files | William Troeak | Revit Architecture - General | 1 | 2007-10-19 12:59 AM |
| Hardware selection-game card vs. processor card.. dual monitors | carmen.martinez | Hardware | 15 | 2007-09-18 12:59 PM |
| Journal File format | Gordon.Price | Revit Architecture - Tips & Tricks | 9 | 2007-09-12 11:53 AM |
| What's up with Hardware Schedules | chris.80515 | Revit Architecture - General | 11 | 2005-06-02 05:12 PM |
