Thursday, September 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit in General > Revit - Platform
 Welcome, Guest.
Login
Revit - Platform The place for your general Revit questions or commentary that are appropriate for all versions of Revit.
Reply
Thread Tools Display Modes
Old 2008-01-02, 06:43 PM   #1
Rick Houle
Rick Houle appears to be going the right way
Exclamation unspecified error - Y2k8 bug..?!
I am currently on Revit-2008 (build 20070607_1700)
Now that my PC clock reads January, 2008 I get an "unspecified error" when I try to edit a group in my family tree, or try to save out a group... I can still edit the group in-place but that is it.
When I change my PC clock to read 12-31-2007 or earlier, the function works properly.
Can anyone please advise if this is the case on newer builds as well..?!
Rick Houle is offline   Reply With Quote
Old 2008-01-02, 06:50 PM   #2
truevis
truevis's Avatar
truevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of light
Default Re: unspecified error - Y2k8 bug..?!
I believe that we need to be using the latest build before we try to effectively track down any bugs.
truevis is offline   Reply With Quote
Old 2008-01-02, 07:22 PM   #3
patricks
Certified AUGI Addict
patricks's Avatar
patricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moon
hmm same thing is happening for me in SP2 20070810.
Guess I need to install SP3 and see if it still happens.
*edit* yep still happens on the most current build.
I merely changed my computer's date to Dec. 31 2007 and then it worked just fine. When I changed it back, it once again said Unspecified Error when trying to open the group to edit or save out the group.
__________________
Intern Architect
AERC, PLLC
Hernando, Mississippi
patricks is offline   Reply With Quote
Old 2008-01-02, 08:35 PM   #4
aaronrumple
Revit Mararishi
aaronrumple's Avatar
aaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining star
Yep. Same here.
A big happy new year to you from Autodesk....
__________________
Don't drink the Kool-Aid...
Aaron Rumple, AIA
aaronrumple is offline   Reply With Quote
Old 2008-01-02, 08:46 PM   #5
Rick Houle
The problem occurs in the latest build, 20071109_2345, as suspected.
We are probably among the first to discover this. I have never known a programmer, post y2k, to "flex" their builds against their PC clock..!
Old 2008-01-02, 09:45 PM   #6
kenneth.98193
kenneth.98193's Avatar
kenneth.98193 is starting their journey
Just to add a note, the 'Unspecified error' also occurs when selecting a drafting view in the Project Browser and then selecting the 'Save to New File' function. I also recreated the conditions listed here and received the same results. Odd problem. I am currently using RA2008 build 20070324_1700.
__________________
Kenneth Parks
Askew Nixon Ferguson Architects, Inc.
Memphis, TN
kenneth.98193 is offline   Reply With Quote
Old 2008-01-02, 09:48 PM   #7
Justin Marchiel
Justin Marchiel's Avatar
Justin Marchiel is a beam of lightJustin Marchiel is a beam of lightJustin Marchiel is a beam of lightJustin Marchiel is a beam of lightJustin Marchiel is a beam of lightJustin Marchiel is a beam of lightJustin Marchiel is a beam of lightJustin Marchiel is a beam of lightJustin Marchiel is a beam of lightJustin Marchiel is a beam of lightJustin Marchiel is a beam of light
the same error occurs with older builds as well. 20070810_1700
Justin
__________________
"Always two there are, no more, no less: a master and an apprentice." Yoda
Justin Marchiel is offline   Reply With Quote
Old 2008-01-03, 12:22 AM   #8
darren.lewis
darren.lewis is starting their journey
Unhappy Re: unspecified error - Y2k8 bug..?!
File>New>Project>Template=None>Pick your units...Unspecified Error. I can recreate this error in the following Revit products: Revit Architecture 2008, Revit Structure 2008, Revit MEP 2008, Revit Building 9.1, Revit Structure 4.0. Moreover, I have solid evidence that this procedure was functioning properly on Friday, 12/28/2007. After acknowledging the error message by clicking okay, the new file, predictably, was not created. When closing the Revit session, I get an unrecoverable error message.
darren.lewis is offline   Reply With Quote
Old 2008-01-03, 02:37 AM   #9
ed.76566
ed.76566's Avatar
ed.76566 is starting their journey
I was able to recreate this error in:
Revit Architecture 2008 build 20071109_2345
Revit Structure 2008 build 20071209_1300
Revit MEP 2008 build 20071109_2345
"unspecified error" on all and crashed on all
Application: Revit Architecture 2008 Version: 2008.000 Error: Unhandled Exception
Application: Revit Structure 2008 Version: 2008.000 Error: Unhandled Exception
Application: Revit MEP 2008 Version: 2008.000 Error: Unhandled Exception
This can't be good.
Ed
ed.76566 is offline   Reply With Quote
Old 2008-01-03, 05:19 AM   #10
cphubb
cphubb's Avatar
cphubb is a beam of lightcphubb is a beam of lightcphubb is a beam of lightcphubb is a beam of lightcphubb is a beam of lightcphubb is a beam of lightcphubb is a beam of lightcphubb is a beam of lightcphubb is a beam of lightcphubb is a beam of lightcphubb is a beam of light
Same problem here with the Group Editing. I also got the Crash at the end of the session. Good thing it comes after the save. I have a support request in to AD I will see what the resolution is
__________________
Chris
If I can write Haiku while Inmates beat me with soap I can concentrate anywhere -- Sideshow Bob
cphubb is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Group edit - Unspecified Error ErichB Revit - Platform 6 2008-01-04 04:55 PM
Schedule Formating Sq M to Sq Ft error/bug psteel Revit Architecture - General 4 2006-09-27 06:53 PM
"Tool not Executed" "Class not registered" unspecified error sfickettj ACA General 1 2005-11-15 07:35 AM
Automation error unspecified mjsregister VBA/COM Interop 3 2005-02-03 04:40 PM
Is it a bug? (Rename view causes unrecoverable error) mark_a Revit Architecture - General 2 2004-09-13 07:52 PM
